C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
lowering C8
Old Jul 3, 2025 | 09:58 PM
olelucky's Avatar
olelucky
Default lowering C8
My new 2025 Z06 came in last Friday. If I lower it (non front lift) will I need an alignment?
Old Jul 4, 2025 | 12:19 AM
Mitchell_B's Avatar
Mitchell_B
You absolutely will and whoever does the alignment needs to have the tools and knows how to set the rear caster or your car will never handle right.
Old Jul 4, 2025 | 12:30 AM
givoltage's Avatar
givoltage
Sounds like a street-only car? Get an alignment if you want even tire wear and the least amount of tramlining possible. You likely won't notice any handling difference on the street regardless.
For track, alignment is a must and rear caster is important as mentioned above.
I'd worry more about ground clearance than alignment. Without front lift it's already quite vulnerable. Adding lowered ride height you'll probably sustain lots of damage. Hope you've got good roads.
Old Jul 4, 2025 | 07:01 AM
HFRAZ's Avatar
HFRAZ
If you lower it be prepared to have the front nose repaired. I went over just a minor change in elevation leaving a parking lot entering highway and front nose scraped. Had lift on Stingray had it set for this area forgot about until it hit in Z06. Luckily not much damage I had thoughts of how much it could cost to fix if necessary. Recommend all get lift in future purchases.
Old Jul 5, 2025 | 05:56 PM
DeltaT's Avatar
DeltaT
CF Community Team
Originally Posted by HFRAZ
...Recommend all get lift in future purchases.
Now you tell me . I do wish I had sprung for it! Would have made street driving less worrisome.
To lowering C8
