C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
question about the ordering process
Old Jul 29, 2025 | 03:53 PM
balaguru's Avatar
balaguru
Default question about the ordering process
If your order is in the 2000 status does that mean that you are still subject to constraints. I have a 2026 3LZ Z07 on order and was called by the dealer this morning notifying me that it was moved to the 2000 status. I had previously heard some of the Z07 aero stuff was on constraint and I'm trying to guess how quickly I might get a build date.
Old Jul 29, 2025 | 05:16 PM
See Ate's Avatar
See Ate
If your order is at 2000 today its likely in the placed tab and changes can be made until 9pm EST (I think) and all constraints for this week have been sorted out. I other words, you either got them, or you didn't, and the dealer knew early this morning. Your order will go into the system (3000) tonight and afterwards cannot be easily changed. If you do request a change, it will always be subject to the same constraints. Once it goes past 3000 it cannot be changed at all. Hope this helps.
