C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Replacement Pads C8
Old Oct 19, 2025 | 12:49 PM
chrismzo6's Avatar
chrismzo6
Cruising
Default Replacement Pads C8
Need to replace the front pads on my steel brake-equipped 2023 Zo6.
Hate the dust produced by the OEM pads even when it's not tracked.
Any suggestions, preferably ones that don't squeal?
Thanks, Chris
Old Oct 19, 2025 | 04:04 PM
Raffi_Z06's Avatar
Raffi_Z06
Love my powerstops
Old Oct 19, 2025 | 04:37 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Carbotech works good as well.
Old Oct 20, 2025 | 10:26 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Oct 24, 2025 | 09:13 PM
Misty C8 Z06's Avatar
Misty C8 Z06
Thanks, Chris
i have z26 powerstops. Got from rock auto. Did all
four wheels. They work well but not a track capable
pad.
Old Oct 24, 2025 | 09:46 PM
BIG Dave's Avatar
BIG Dave
I switched over to Carbotech 1521. Noticeably less dust. Installation was straightforward. I will absolutely do it again on my next Corvette!
Old Oct 24, 2025 | 10:20 PM
mtraylor2001's Avatar
mtraylor2001
I hear some people saying in other threads that the carbotech's dont have a back plate and cause a clacking noise. Can anyone elaborate on this? Also I have read on some other posts that the stopping power is not as good as OEM pads and that its a little squishy which can be counteracted by putting the brakes in track mode on say zmode to make up the difference. Can some people elaborate on this? Also hearing they can squeak allot. Is that an installation issue because some say they dont.
I have been waying heavily on changing out the pads just to try them out with all the posts I see, but not sure the juice is worth the squeeze from the counter active posts. If you are an aggressive driver normally who also likes to got he track every now and then, what are thoughts from those people? I understand they dont work on track, but I dont want squishy brakes on the street either. What is 60 to zero and 130 to zero braking times compared to OEM?
Old Oct 25, 2025 | 08:01 AM
BIG Dave's Avatar
BIG Dave
Originally Posted by mtraylor2001
I hear some people saying…
After installing my 1521 pads, I did find I wanted a little more bite so I changed the Brake setting to Track and now they feel like OEM pads. Regarding squeaking, I have zero noise. Perhaps the people that are reporting noise didn’t use the proper GM copper paste grease (GM part number 19303310)? Here is an install procedure I put together:
1. Windows down
2. Shut off car and disconnect battery
3. Keep hood open (doors can be opened by reaching in and pulling the Emergency Handle on the floor)
4. Remove lug nuts with 22 mm socket
5. Front Calipers - Remove 13 mm bolt
6. Hammer out two pins from each front caliper
7. Remove retaining clip
8. Slide out old pads
9. Add coper paste to sides of new pads (GM Lubricant 19303310)
10. Slide in new pads
11. Reinstall retaining clip, torque bolt to 18 LBs
12. Replace pins
13. Reinstall wheel, torque lug nuts to 140 LBs
14. Rear Calipers – Same as front except no 13 mm bolt
15. PUMP brakes until firm pedal feel!!!
16. Reconnect battery
17. Reindex windows
Old Oct 25, 2025 | 12:23 PM
mtraylor2001
Anyone have info on the clacking sound and brake effectiveness vs the OEM pads?
To Replacement Pads C8
