C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
sensitive battery?
Old Oct 29, 2025 | 10:58 AM
topcarbon's Avatar
topcarbon
2020 C3 of the Year Winner- Unmodified
Default sensitive battery?
Since I am new to the Z06, I am asking if the battery drain is more than other modern cars? I made the mistake of having my detailer leave the doors and frunk open for an extended time without plugging in the tender. I wok up this morning and the lights were flickering and car would not start. so I plugged in the tender and left it. Though it was not left over night with lights on. there was a time with the car on but not started and the battery was drained to a point it would not start. Other cars ive owned were not this sensitive..
Wondering
Old Oct 29, 2025 | 11:52 AM
noticket's Avatar
noticket
Wondering
I would have to do more digging to find it but some folks tested the parasitic draw with everything closed and it was very very low.
I do think the battery drains more with things left open tho. Just speculating as I haven’t tested it.
My car came from the factory with a bad battery that would barely stay alive even with a tender. I swapped it out and haven’t had any more battery charge issues.
Old Oct 29, 2025 | 12:49 PM
24RiptideBlue's Avatar
24RiptideBlue
Wondering
If it’s not allowed to power down completely, doors left open etc I would say there is more electronic stuff awake than any of my other cars…
I find interesting that I leave my car on the “official” tender, which reads “battery fully charged” when I disconnect and take the car out. Drive the car for an hour or so during the day, so no headlights. Return home and put the tender back on and it’s reading that the battery is taking a charge?
I don’t understand why a fully charged battery, that was used to start the car once for a 60 minute drive, that included highway speeds, needs additional charging post drive?
Old Oct 29, 2025 | 02:05 PM
jeremyjay46's Avatar
jeremyjay46
Those smart chargers take a little time to analyze the battery state when you first connect them, even if they are fully charged. After a few minutes, does it still say charging? It's probably just analyzing and "topping off".
Old Oct 29, 2025 | 03:12 PM
markd's Avatar
markd
I believe the car only charges to 80% capacity when driving. This is to achieve best fuel economy. So effectively the computer allows the car to go down from the 100% battery tender charge when you drive and won't start charging until it falls below the 80% mark.
24RiptideBlue
Wondering
If the car was left with doors open I believe it shuts itself down after 10 minutes. But if people are in and out working on the car it will prevent the car from shutting down which will drain the battery. Once the battery is low, in my experience it takes at least overnight on a tender/charger to bring it back to fully charged.
Most new vehicles are like this. They have so much tech. So many computers, networks, external connections that use the battery… every C8 has its own LTE cellular connection and is constantly trying to “phone home” and transfer data to GM HQ, where you go, when, at what speed, how hard you braked, if you had the window down, when you put the window down, vehicle temperature, transmission temperature, tire pressure, and millions more “data points” are constantly being transmitted. All GM cars do this now although the car is supposed to have a “low power” mode to transmit data when the car isn’t running (and battery not charging).
Old Oct 29, 2025 | 03:21 PM
24RiptideBlue
I agree with above but it seems to take some time for the tender to go from level 1 to level 3 (fully charged). I have never measured how long it takes but it’s not instant or even five minutes so the battery is taking a charge when I don’t think it should need to… it’s just an observation…
Old Oct 29, 2025 | 03:38 PM
24RiptideBlue
Wow I hope you’re wrong… saving a minuscule amount of fuel at the expense of keeping the battery fully charged is…. Ummmm…. Not ideal…
I was of the understanding batteries should remain fully charged for maximum life and reliability. Especially if you live in the north where cold temperatures reduce battery power… the above would indicate a car might not start in freezing conditions where a fully charged battery may work.
My Z06 is averaging 12.5 MPG… apparently it’s not improving my fuel economy…
Old Oct 29, 2025 | 06:53 PM
topcarbon's Avatar
topcarbon
Thanks for all the
comments
the tender kept going to red. I said screw it and purchased a battery. I do not need to get stranded because I was trying to revive a dead battery.
Old Oct 30, 2025 | 03:49 PM
Bill W's Avatar
Bill W
Not scientific data, but my car doesn't like anything but a full charge. Even if it starts, other electric gremlins show up if I don't keep it on the tender. Things like the radio freezing on one channel.
Old Oct 30, 2025 | 04:02 PM
topcarbon's Avatar
topcarbon
I changed the battery yesterday and that was probably the easiest battery change that I’ve done for at least 15 years. There are some advantages to purchasing an American car versus a European car.
Old Oct 30, 2025 | 04:11 PM
smithers's Avatar
smithers
That and they aren’t really chargers. They are more like battery maintainers that go thru different cycles. It’s not like charging a phone where it just charges to 100% and holds it there.
Old Oct 30, 2025 | 06:12 PM
tramminc's Avatar
tramminc
My 2014 ctsv with automatically shut power off to prevent that.
Old Oct 31, 2025 | 04:50 PM
thrilled's Avatar
thrilled
If your battery is fine then minimum drain if at all. I have parked mine for a couple weeks with no tinder. It started right up
To sensitive battery?
