C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Engine Tick Update
Old Dec 10, 2025 | 05:41 PM
stoessjc's Avatar
stoessjc
Default Engine Tick Update
2025 Z06/Z07 Coupe. Engine tick seemed excessive. Took car to the local dealer and they told me that it would cost me $450 to do the sound measurement, since the TSB did not cover 2025 builds. Asked the service writer to just listen to the engine and give me his opinion. When he heard how loud the ticking was, he called out a technician to listen and both agreed that it seemed excessive. Informed me that GM would need to authorize the sound measurement to be made under warranty and that the process could take as long as a month. I was leaving for a trip so I left the car. Upon returning, was informed that GM rep approved the TSB to be performed under warranty. I now await the results of the sound measurement.
Old Dec 10, 2025 | 09:14 PM
Mitchell_B's Avatar
Mitchell_B
Are you the original owner? What is the mileage on the car? Did this tick develop over time or did the car always tick since you've owned it?
Old Dec 11, 2025 | 05:13 AM
VinnyP's Avatar
VinnyP
I had no idea the "tick" t.s.b. didnt include 2025's.
Old Dec 26, 2025 | 09:42 PM
stoessjc's Avatar
stoessjc
I am the original owner. Car has 580 miles. The ticking noise was always there. Gets louder as oil temp increases. The TSB only cover the 2023 model year. GM approved the TSB for my 2025. Just got update that the dealer has ordered cam caps but they are on back order. Replacing the cam caps is not part of the TSB. Only a retorquing of the caps is included in the TSB.
I have a major concern about replacing the cam caps. What I know about other DOHC heads, the manufacturing of the valve train includes placing the cam caps on the cylinder head and then line boring the assembly to get concentricity for the camshaft to fit with the proper alignment and clearances. You cannot just replace a cam cap with a new one with assurance that alignment is maintained. I need to find out more about why and how the repair is being performed. On DOHC engines I have worked on, the cam caps are numbered and must be returned to their original location and orientation to avoid problems.
Old Dec 26, 2025 | 10:30 PM
Mitchell_B's Avatar
Mitchell_B
Whoever will be doing the warranty work should follow the TSB - which does not include replacing the cam caps. The caps and their location are matched to the head. Arbitrarily replacing caps is like replacing main bearing caps. This necessitates possible machining and definitely line honing the mains. Same with the cam caps. You cannot just throw new cam caps on a head and expect everything to be okay. I would request that the dealer call in a field engineer to work with them. It seems the dealership shop is going about this wrong.
To Engine Tick Update
