Z07 launch settings
I had a blade silver C7 Z06 with carbon fiber hood before this, and the C8 drives much differently. Fun in it's own way, but I did like the immediacy of the torque in my 2016 Z. I had tracked my C7Z when I had it. I hope to do the same with the newZ.
I believe I am discovering some drive modes that is helping with the sluggishness perceived at lower RPMs in the new Z. I have set my Z mode to sport suspension, steering, braking, and track engine, exhaust. The sound is awesome! It does make my ears ring a little because of hearing damage I sustained from a bear hunt few years ago, but it's worth it! Ha.
I have been disappointed at the lag I've felt below 4500rpm and at launch during street driving from my Z mode with no other adjustments. In mine, the PTM settings cannot be used except from a track suspension setting. It sounds like track suspension is supposed to be reserved for actual track days because it may be too harsh for daily/street driving (ie. suspension/wheel damage on poorly maintained roads?). Maybe someone can chime in on this, I'm getting mixed signals from various sources.
That being said, I'm learning that if one drives in PTM settings of sport 1 or sport 2 while in track suspension setting, it modulates the torque/throttle responses and TC/ESC interventions. The PTM settings are an advanced traction mgmt suite with custom engine torque delivery, traction thresholds, stability/yaw control, and torque vectoring via electronic brake regulation. Supposedly the feel is more immediate throttle inputs available. However, the trade off is some slip that must be controlled by the driver. Not too big a deal with proper experience. I have not experimented with this yet, but will be in coming days.
If one prefers to stay in sport suspension setting during street driving (like me for now), it seems a different TC/ESC intervention setting is achieved by double tap on TC button that puts you in "competitive" mode. That is, TC loosened and ESC still active. It sounds like it is not as advanced a traction mgmt suite like PTM, but does make better throttle response available. I have played with this and there is much better launch and acceleration below 4500rpm. A long press on TC button deactivates TC and ESC. I imaging this would require advanced driver inputs to manage wheel slip and fishtailing under hard acceleration. So far, the Competitive mode has been very manageable.
It sounds like Competitive mode gives greater acceleration because it does not regulate torque delivery like the PTM sport modes. Again I haven't experimented with PTM on street driving yet so I don't have a feel comparison. I have been happy with the improvement in throttle response from Competitive mode thus far.
Hope this helps!
I've prolly done LC atleast 50-60 times at various rpm and slip %. Your Z07 package with the better tires (pending temps outside) with spoiler i wouldnt be surprised if you could get more aggressive on the launch on the street than my non z07 car
