C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
91 octane?
Old Jan 11, 2026 | 11:25 PM
TomZaloga's Avatar
TomZaloga
Default 91 octane?
Unfortunately, I live in a state (AZ) where 93 octane gas isn't available. We only have 91 octane here. From what I understand, 91 octane can possibly cause detonation issues for spirited driving, especially in the heat of the summer.
For those of us using 91, has anyone experienced any issues?
I know I can mix in a couple of gallons of high octane racing fuel (such as Sunoco 100 which is available here), and so I may do that in the summer, but I was curious as to anyone else's experience or approach, if any! 🫣
Old Jan 11, 2026 | 11:39 PM
Semifighter18's Avatar
Semifighter18
Absolutely zero issues with 91 octane fuel. I live in CA in the valley where it routinely is over 100 in the summertime. Nothing but 91 available where I live. LT6 adjusts timing automatically to the octane. No need for additives of any kind. Just drive it and rip on it, you won't notice a thing.
Old Jan 11, 2026 | 11:50 PM
AzDave47's Avatar
AzDave47
Live in AZ high country, which would minimize possible detonation, but you should have no worries. GM knows half the country only has 91 and the engine is fine with that. 93 would be better and a little more of the rated power but no mechanical issues using 91. In the Utah high country their premium is 90 octane.
Old Jan 11, 2026 | 11:59 PM
TomZaloga's Avatar
TomZaloga
Yes, I live in the southeast valley (Gilbert, AZ) and I try not to burst into flames in the summer when it gets north of 115! 🔥
Thanks for the info. Just want to make sure the LT6 can handle it. I miss the days when I was back east and had access to Sunoco Ultra 94.
Old Jan 12, 2026 | 12:13 AM
Semifighter18
GM knew the car would be running 91 only in some states. There is a slight performance drop. You won't get the full 670hp, probably losing anywhere from 10-30hp depending on who you talk to. 91 is safe for the entire life of the engine, period. GM specifically does not recommend octane boosters because the additive chemistry is unpredictable, it's possible emissions can be contaminated, results vary by brand, etc. Best bet is to 50/50 mix of 91 pump and 100 UNLEADED race gas if you can find it but honestly for regular street bubbas like me I doubt it's noticeable.
Everything above is what AI says so take it with a grain of salt, but it sounds pretty good to me.
Old Jan 12, 2026 | 07:17 AM
Kenny94945's Avatar
Kenny94945
91 Calif Fuel ... in C4 to C8 (sold in Cal) Vettes.
Never a detention "ping" issue.
Old Jan 12, 2026 | 08:33 AM
NEVERL8's Avatar
NEVERL8
You can cheat the system to get 93 octane if you can find stations that sell 91 octane ethanol free gas and E85. I have both in my area. With low fuel in tank fill with 91 octane non ethanol. Drive until you have used 3 gallons, then fill up with E85. You'll have 14% ethanol in tank (max allowed by GM is 15%) and you'll have approximately 93 octane equivalent fuel. A pain in the butt to do but it does raise the octane.
Old Jan 12, 2026 | 09:33 AM
AzDave47's Avatar
AzDave47
The Love's gas station off I10 east of the Wild Horse Pass exit does have 100 octane unleaded. When I drive the Wild Horse Pass tracks, i mix in about 5 gallons of the 100 to bring the tank octane up to about 94 for track days. Last time I was there $9 per gallon.
Old Jan 12, 2026 | 09:39 AM
TomZaloga's Avatar
TomZaloga
Yes, I've been there before to add a couple gallons to my former C6. Time for another visit! 👍
Old Jan 12, 2026 | 09:52 AM
AzDave47's Avatar
AzDave47
I am used to the power loss. Up here at elevation I lose about 12% of the power you have down there, both running 91 octane.
As an example of the altitude impact, in my HCI C6Z at 6500' elevation I trapped 176 MPH in the mile. At 2300' elev. I trapped at 188 with the same setup (less 75 # as I took the passenger's seat out to haul track rear tires 400 miles. I didn't want the passenger's outside mirror blocked for that long a drive.
Old Jan 12, 2026 | 11:25 AM
EvanZR1's Avatar
EvanZR1
C4 of Year Winner (performance mods) 2019
It's fine on 91. I ran 2 track days on 91 in my 25 with no issues.
To 91 octane?
