C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Need Torque Help!
Old Feb 28, 2026 | 01:11 AM
jjk2509's Avatar
jjk2509
Default Need Torque Help!
What is the OEM torque specification for the cats to the manifold? I have searched in several places and have not found the answer.
I used AI and Copilot tells me 18# and ChatGPT tells me 33#. The two numbers are too far apart. Any help is greatly appreciated.
Old Feb 28, 2026 | 01:36 AM
TroutButter's Avatar
TroutButter
Google's Gemini AI said this:
For the 2023-2026 C8 Corvette Z06, the bolt torque for the catalytic converter-to-header connection is not explicitly listed in standard owner's manuals but is specified in official service documentation and aftermarket installation guides for the LT6 engine.
The torque specifications are as follows:
  • Header-to-Catalytic Converter Flange Nuts: Most performance guides for the LT6 engine recommend torquing these to 35 lb-ft.
  • Torque Sequence: It is highly recommended to tighten these in a progressive sequence (e.g., 15 lb-ft, then 25 lb-ft, finishing at 35 lb-ft) to ensure an even seal and prevent gasket failure.
  • Notes on Fasteners: The factory nuts on the converter flange are often extremely tight and may require significant force to break loose initially.
  • Heat Shields: The 8mm bolts holding the heat shielding onto the converters typically require much lower torque, generally around 18-22 lb-ft.
For the most precise values, you can reference the official C8 Z06 Service Manual or consult detailed aftermarket guides like those from Soul Performance Products or Fabspeed which specialize in C8 Z06 exhaust components.
Old Mar 1, 2026 | 10:44 PM
Hib Halverson's Avatar
Hib Halverson
Pro Mechanic
Pro Mechanic
Per GMSI: 58 N/m or 43 lb/ft
Old Mar 2, 2026 | 05:12 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Catalytic Converter Brace Bolt
22 nm  (16 lb ft)
Catalytic Converter Heat Shield Bolt
10 nm  (89 lb in)
Catalytic Converter Nut
58 nm (43 lb ft)
Exhaust Bracket Stud
10 nm  (89 lb in)
Exhaust Control Valve Actuator Bolt
10 nm  (89 lb in)
Exhaust Hanger Bracket Bolt
22 nm  (16 lb ft)
Exhaust Heat Shield Bolt @ Exhaust Heat Shield - Upper and Lower Muffler (LT2 Without NCL)
8 nm  (71 lb in)
Exhaust Heat Shield Bolt @ Exhaust Heat Shield - Upper and Lower Muffler (LT6 Without NCL)
12 nm  (106 lb in)
Exhaust Heat Shield Bolt @ Exhaust Muffler Heat Shield & Exhaust Heat Shield - Upper and Lower Muffler (With NCL)
10 nm  (89 lb in)
Exhaust Heat Shield Retainer
1.5 nm  (13 lb in)
Exhaust Manifold Heat Shield Bolt (LT2)
10 nm  (89 lb in)
Exhaust Manifold Heat Shield Bolt (LT6)
9 nm  (80 lb in)
Exhaust Manifold Nut
9 nm  (80 lb in)
Exhaust Muffler Hanger Bracket Bolt @ Exhaust Rear Muffler Insulator
22 nm  (16 lb ft)
Exhaust Particulate Filter Hanger Bracket Bolt @ Exhaust Heat Shield
6 nm  (53 lb in)
Exhaust System Rear Nut
22 nm (16 lb ft)
To Need Torque Help!
