This has fixed, thanks everyone.Has anyone installed the soler throttle controller? And as soon as you plugged it in, you started the car and got a check engine light?
Reason: Fixed
I installed mine with no issues. Did you move all the key fobs a safe distance away from your car during the install? If not, that’s probably the cause. Disconnect the battery for 10-15 minutes and see if the check engine light goes away.
i think you're right.I pulled this off my c.A and then started on my z 06 and forgot all about supposed to have the key away from the vehicle
Make sure the connectors are properly seated. One of the ends has a little play. Ensure both are tight. Disconnect the battery for a few minutes and try again.
My buddy got the light when we installed his last year. We follow the directions to the letter tried several things but couldn't clear light. Sent it back got a new one and all is well.
