Fluid filter question
anyone know if it’s available anywhere cheaper?
I want genuine GM.
I see it on Amazon for $105, says it’s GM OEM, but is it really?
does anyone know the part numbers for all three(engine oil filter, trans fluid filter and replacement drain plug)?
this is for a 2025 Z06.
Transmission external filter kit - 24045729, $114.79
Engine oil drain plug - 55577568, $7.84
Oil tank drain plug - 12713651, $3.50
Transmission fluid (quart) - 104130, $22.79
All these are listed in Rockauto.
The metal drian plug and the engine oil filter cap get torqued to 18 lb-ft.
The 4 torx screws that retain the transmission filter cover get torqued to 53 lb-in.
Save all your receipts in the event you need to show for warranty purposes that you performed maintenance on the car.
