C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Autocross wheels
Old Yesterday | 08:33 AM
masihman's Avatar
masihman
Default Autocross wheels
Has anyone been able to find SCCA compliant autocross wheels that are 1 inch smaller than stock size (or 2 inch smaller rear) so that you can run a better set of tires? The offset needs to match stock within 7mm I believe. I don't want to spend a fortune as they'll only be used for autocross. I love autocrossing this car but without a proper set of tires I'm just not competitive. I suppose I should start cooling the PS4S tires between runs as they get way too greasy after the second run. Please advise if you've found any. Thanks!
