2m cat deletes installed-
#41
EOS makes resonated cat-delete pipes that retain the factory heatshields, and they're cheaper than 2M. They're a forum vendor too.
https://eosexhaust.com/products/2021...ytic-converter
The following 2 users liked this post by Kracka:
smoove7410 (12-28-2023),
Tristen1963 (12-28-2023)
#42
#43
Agree, they are dicks for sure. I have seen videos of people cutting stock cats open and gutting and rewelding.
#44
Gopro max, the ghecko 3 suction mount (wouldnt recommend, I had to make a support beam and the suction cups I do NOT trust, I have had issues already without actually drag racing yet.) I am still figuring out a reliable setup.
#45
Still not certified due to grade but they def added some 60-130 power. Best I could muster before was 7.6. (It was colder in this pass than the others)
#48
From GM's website:
Drivers side cat Z06 5.5L
12704809
Drivers side cat STINGRAY 6.2 L
12704809
12704809
12704809
The following 2 users liked this post by Z51 John:
Irpilot (12-30-2023),
Last Hurrah Z (12-29-2023)
#50
Well that confirms it. A few months ago I was 99% sure just based on doing the same cat job on both my stingrays and now the Z. That paired with the fact they use the same gaskets lol
#51
Kracka (12-29-2023)
#53
They have o2 spacers welded on, but you may need additional o2 spacers if a CEL pops. I'd recommend Big Daddies Garage angled spacers for quality that fits correctly and won't rust.
I'd also suggest a brand new set of 4 OEM gaskets to prevent having to go back in there again.
GatorsJMC (12-30-2023)
#54
The following 3 users liked this post by Kracka:
#55
Gasket info with GM part numbers: https://www.corvetteforum.com/forums...post1604776535
Last thing I want is to do the install twice....
Kracka (12-30-2023)
#56
FYI
#57
Looking to get these as well for up upcoming Z. They don't seem very helpful according to their website, are there any known fitment issues?
I have fabspeeds on my stingray, went in smooth
#58
No fitment issues and no CEL. Get new OEM gaskets though cause the 2M supplied ones are trash. Also use Ultra Copper on O2 sensor threads. Leaks, even the smallest, will be a CEL. I used titanium heat wrap on mine as well. No issues at all
#59
Helpful info. With the part numbers matching up can anyone confirm pipes from a stingray fitting a z06? I can take measurements of my oem stingray cats if it helps
#60
