C8 Z06 Belmont 18” Weld wheels
Dig
Sorry I missed this thread,, saw the others. I didn't realize you had all the issues without the e-brake not plugged in. Not that it's any help now, there's a guy on here that put an AP big brake kit on the rear and he opted to move the e-brake into the trunk and put a block of wood in it to simulate the rotor.
Z51 Parking Brake?? - CorvetteForum - Chevrolet Corvette Forum Discussion
See post 3
See post 3
Dig
Check engine light came on and traction control lights would flash when in 5th gear under load. Both lights are staying on. Sometimes in manual mode the car will not shift even with me pulling the paddle. Weird. Tire height might be the issue ? This drag packed worked perfect on my 2023 Stibgray 🧐
what are tire sizes you have now? Based on tire you listed above at 315/30/18, the tire is 2.34” shorter in height.
123sugey (04-26-2024)
Dig
Wondering … if I switch over to a 28” tall drag radial in the back that would take care of these issues. The C8 platform is more finicky than the stray cat I’m feeding right now 😉
racerx8 (04-27-2024)
Short tires are going to get you into 4th gear earlier but should be faster. This site is helpful. Shows 133 MPH 4th gear with 315/30/18 versus 145 MPH in 4th gear with stock sizing.
https://www.speedcolumn.com/car-gear...-Corvette-2023
#33
Dig
As it is right now with the Z … I can’t engage launch control. No cell at all. So that’s good but I need to figure it out as far as launch control. Getting that to work. If not I’ll have lazy 1.9 60’s
#34
Yeah I'm aware but cutting it close you don't want it to auto shift up prematurely. I'd try it first and if it does that then switch to manual mode when you're in 4th gear to let it rev out. You mentioned going to 325s that should help get a little more MPH too.
123sugey (04-29-2024)
#35
Dig
#36
Hope you don't mind me using your thread to bounce a few things around.
I have a 2024 Z51 with mag ride. last week I installed my drag pack rear wheel/tire set up and all is good.
Today I installed my front drag wheel/tire set up and took the car for a ride and as expected the front TPMS warning light came on as expected.
Ok, I do have the TPMS in the rears because they will fit. Fronts, not so much.
It will not go into launch mode now. I guess without the front TPMS in place it's not gonna happen.
Thoughts?
Maybe look into building one of those PVC pipe containers with the TPMS inside?
For the short term I'll throw the front stockers back on I guess.
Thoughts?
#39
Dig
Ok, I do have the TPMS in the rears because they will. fit. Fronts, not so much.
Thoughts?
Thoughts?
