C8 Z06/ZR1/Zora Discussion General Z06, ZR1 and Zora Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Removing Center Grille Trim
Old 02-27-2024, 05:49 PM
MVPJEFF106
MVPJEFF106's Avatar
Default Removing Center Grille Trim
Does anyone have directions to remove the center license plate trim piece in the z06 grill opening so its a wide open grill? I remember seeing it somewhere but can't find it. Thanks.
Old 02-27-2024, 05:53 PM
z28lt1
Support Corvetteforum!
z28lt1's Avatar
Received 2,057 Likes on 1,072 Posts
I'm sure there are instructions somewhere, but it's simple. Remove the two plastic pieces on either side (one is the same as the tow hook) and then remove the screws. Nothing to it...
Old 02-27-2024, 05:58 PM
robob
robob's Avatar
"Remove the two plastic pieces on either side"
How?
Old 02-27-2024, 06:09 PM
FL-355
FL-355's Avatar
I did mine a few months ago and I'm going from memory - my car is at the dealer having the rims changed - so I will try to do my best.
Sit at front of car - to the left and right of the center piece are 2 small squares by camera - pop them off with a plastic trim tool. That will expose 2 screws - remove screws and center panel will remove.
But, it leaves behind a backing plate - there are 2 plastic screws. Only turn them 1/4 of a turn - they hold similar to a jacking puck, so you only need to turn them and wiggle.
Replace outboard screws for safe keeping, pop the plastic covers back on - done.
Again, going from memory and I'm sure someone will correct me if I forgot something....
The following 3 users liked this post by FL-355:
Corvette4Life_01 (02-27-2024), MVPJEFF106 (02-28-2024), robob (02-27-2024)
Old 02-27-2024, 06:35 PM
Corvette4Life_01
Corvette4Life_01's Avatar
Old 02-28-2024, 08:48 AM
3LZR21U
3LZR21U's Avatar
Could have sworn someone said this was in the Owner's Manual.
Glennm27 (02-28-2024)
Old 02-28-2024, 08:49 AM
MVPJEFF106
MVPJEFF106's Avatar
Thanks everyone, Trim was removed. Easy process as indicated above!
The following 3 users liked this post by MVPJEFF106:
Corvette4Life_01 (02-28-2024), Fast@night (02-29-2024), oaktreebc (02-28-2024)
Old 04-10-2024, 09:50 PM
vipervetteguy
vipervetteguy's Avatar
Is here any downside to removing these panels? I do think it looks better.
To Removing Center Grille Trim
Quick Reply: Removing Center Grille Trim
