I think I got to replace my fuel filter, took it on the highway this weekend, on WOT the secondaries were not opening, the car wanted to stall unless I took my foot off the gas. I got a filter at home.
Problem could be both, driving on city streets was fine.
Any Suggestions, want to make the April 23rd event.
Did a search, here's Lars answer to the same problem.
Sounds like fuel starvation at WOT - you're going lean. Causes include:
1. Low float level
2. Dirty filter
3. Kinked rubber fuel line either back at the tank or at the forward frame rail
4. More than 1 fuel filter installed (in-line filter somewhere in the system in addition to the in-carb filter)
5. Dirty tank pick-up sock
6. Poor fuel pressure (bad fuel pump)
7. Incorrect secondary metering rods (too fat)
8. Incorrect secondary airvalve spring windup (should be at 3/4 turn) - loose spring will cause lean secondary operation
