DIY changing clutch fluid... PATMAN?!?
![](/forums/images/ranks/5k-6k.gif)
2021 C6 of the Year Finalist - Modified
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Just reading on Ranger's website about changing clutch fluid for all LSX engines. Makes perfect sense, and I remember having my clutch petal stick a few times on my LS1 Trans Am, scared the heck outta me! Hasn't happened yet on the vette, but I don't think I've changed my clutch fluid yet, and I'm almost positive its dirty by now. Looks very easy to do, and cheap, a GREAT combination! I love being able to do my own stuff on my car, even if it is very limited.
You can check the how-to on Ranger's site here: http://www.rangeracceleration.com/Clutch_Care.html (lots of other good stuff on here too!)
Anyone else done this yet?
And question for the resident CF fluids expert, Mr. PATMAN, which clutch fluid do you recommend?! GM brand DOT3? Or is there a better brand? He also says you can use Synthetic DOT4 as long as its specified on the can, and one last thing, anyone know how much the car requires?
Ok, one LAST question, where can I get a syringe? Or will a turkey baster fit in the cylinder? Don't have my car here to check, so I can't see it to know. I want to do this when I take my car out of storage, get most of that old, dirty, stagnant clutch fluid OUTTA there!
...in 35 days!!!
...in 35 days!!!
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/3k-4k.gif)
St. Jude Donor '07
...in 35 days!!!![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
...in 35 days!!!
This exceeds dot 3 & 4 .
Great product ,just make sure you clean your current system of all the factory fluid so you don't mix.
Avialable at Crappy Tire .
The syringe's are avaible at TSC in the (horse section
![Beating a Dead Horse](https://www.corvetteforum.com/forums/images/smilies/beatdeadhorse5.gif)
![LOL](https://www.corvetteforum.com/forums/images/smilies/lol.gif)
There ya go Corrado
![Yes Nod](https://www.corvetteforum.com/forums/images/smilies/yesnod.gif)
Corrado, I picked mine up at a local TSC store, but then I'm not in the 'big city'. It was a 35mm syringe that does it in one shot. Get yourself a small funnell as well because you don't want to spill any of this stuff either. Get a big bottle because once you see how easy it is to do you'll be doing it more frequently...next time you cross the border pick it up there...it's almost half the price. As for the brand...opinions will vary...but at the end of the day...as long as you change it often that's what will count.
Greg
Greg
![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
Awesome! thanks everyone!
Joe, thats right I remember you changed it for me bud, now THATS good service!!!
Still wanna do it myself on a regular basis though, also should do it on my Rav4, I doubt its EVER been done on that thing!!
TSC?! Whats that place?? I'll do a search on that....
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
Try TSCstores.com...but the only 'bridge' they're located in is Cambridge. If you want I can pick you up a pair and bring them to the P&B tomorrow.
Greg
Greg
![](/forums/images/ranks/2k-3k.gif)
I just did this on my Camaro a few weeks ago. The small reservoir does not contain much fluid but wow was it BLACK! It took me about 6 times to get rid of all the black fluid. I used a turkey baster and it worked well for me. I do the same thing with my Brake Fluid and Power Steering Fluid. Fluids are cheap, might as well keep them clean!
Jason
Jason
Hey thanks for the offer Greg! I have a turkey baster, so I'll use that, its never been used, don't make many turkeys!
Jason, you're right, fluid is cheap, this is an easy way to take care of our cars without breaking the bank.
![](/forums/images/ranks/500-1000.gif)
Actually, Corrado I did have that clutch petal sticking issue on my C6. If you think it scared the crap out you in the T/A, try in the vette. If you do get this problem, there is a TSB out there and GM will fix it under warranty (some spring issue).
I do my clutch fluid several times throughtout the season (also track my car), I usually use Prestone DOT 4, not too expensive and never had any issues with it.
FYI, for my brakes I use Motul RBF 600 which is also a DOT 4 but costs considerable more money....but I don't want to skimp on brakes!
St. Jude Donor '07
FYI, for my brakes I use Motul RBF 600 which is also a DOT 4 but costs considerable more money....but I don't want to skimp on brakes!![Cheers!](https://www.corvetteforum.com/forums/images/smilies/cheers2.gif)
![I Agree!](https://www.corvetteforum.com/forums/images/smilies/iagree.gif)
![EEK!](https://www.corvetteforum.com/forums/images/smilies/eek6.gif)
So don't skimp the small things like quality fluids
![](/forums/images/ranks/7k-10k.gif)
![](/forums/images/ranks/100-500.gif)
![](https://www.corvetteforum.com/forums/images/ranks/cf10.jpg)
I use castrol SRF, i get it from my castrol rep. Everything else I tried would go black pretty quick.
Exceptionally high dry boiling point of 590ºF (Wet 518ºF)
Superior anti-vapor lock properties
Safe for all non-mineral oil-based disc and drum brake systems
Exclusive European formula!
Exceeds SAE 1703, ISO 4925, JIS K2233, FMVSS No. 116 DOT3 and DOT 4
