Canadian Events Canada, eh?
Check Engine Light
Old May 6, 2008 | 01:32 PM
spicytuna's Avatar
spicytuna
Default Check Engine Light
Doh!
I keep on getting a CEL on P0161 which is for the rear right O2 sensor.
I guess I'll have no choice but to get myself a set of long tube headers and high flow cats along with a tune to get rid of that sensor reading.
Old May 6, 2008 | 01:38 PM
GettReal's Avatar
GettReal
LOL...I like the way you think
Old May 6, 2008 | 02:48 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Originally Posted by FRC Ken
Doh!
I am ready when you are
Manny@E.C.P
Old May 6, 2008 | 03:18 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
There was a guy on a LS1tech selling a brand new LG Street Series for $1000. Sounds like a good price.
Old May 6, 2008 | 03:54 PM
spicytuna's Avatar
spicytuna
I was thinking of going all out and going with either the LG Pro or Dynatech Supermaxx headers.
They both cost around the same price (~ $1900 shipped) and although I'm leaning towards the LG Pro's due to their popularity, my local shop swears by Supermaxx and tells me that they're slightly easier to install than the LG Pro's.
With that being said, maybe I should message that guy who's selling the LG Streets. That's a good price indeed...
Old May 6, 2008 | 03:55 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Doh!
Ken how about a brand new set and shipping is on me
Manny@E.C.P
Old May 6, 2008 | 03:58 PM
E.C.P's Avatar
E.C.P
St. Jude Donor '07
Most of the top brands are very much the same as far as install. The LG's have proven time and time again to be the best on the market. The Street Series are an excellant buy ,new or used .The Pro's are the best it gets and offer you much better gain's overall . If you plan on going to a power adder or into the 500hp range ,they are the way to go.
Manny@E.C.P
Old May 6, 2008 | 04:52 PM
JPEAK's Avatar
JPEAK
http://www.neweraperformanceparts.com/default.asp?S=503&A=E&PKV=dynatechc5|0
Old May 6, 2008 | 04:55 PM
spicytuna's Avatar
spicytuna
Manny,
I understand that the longer primaries of the LG Pro's are designed to improve low end torque.
Is that the same case with the LG Streets? Or do the LG Streets have shorter primaries?
Old May 6, 2008 | 05:07 PM
WildWilly55's Avatar
WildWilly55
Hey Manny---careful what you say---they are just waiting to pounce!!!!--Heheheheheheheheh!!!
Former Vendor
From our testing at the track and on the dyno If you are going to go with a power adder in the future than the LG's are not the way to go. The longer primary will hurt power up top-all the really fast guys with power adders run the Kook's or American Racing headers.
If your staying N/A then the LG Pro's will make more power under the curve than the rest-peak will be the same, but power under the curve will be greater.
Passing an E-test with the LG pro's will be alot harder as well, especially with mods such as a cam. The further back the cat's are from stock the less heat they hold.
Just some info to consider, I can forward some dyno graphs if you'd like!
LG pro's for N/A
Kook's or AR for a power adder
Unless your thinking turbo then you won't need headers at all!
Old May 6, 2008 | 05:11 PM
WildWilly55
Bingo!!!!
Old May 6, 2008 | 05:15 PM
JPEAK's Avatar
JPEAK
Listen to your shop, as Dynatech comes with a complete bolt on package, all gaskets and header bolts. Nothing wrong with LG, they are a great header system, but on your 2000 FRC you will need to replace your air tube that runs behind the intake manifold in order to adapt to the LG. Dynatech have specific headers for your year car so no mods required and they are an easy install. You should be able to get a better price then $1900 shipped.
Old May 6, 2008 | 05:27 PM
Former Vendor
Manny,
LG streets still have the 32" primary but lack the race merge collector that the LG Pro's have. LG pro's also feature a true x-pipe and 3" mid-pipes while the streets have a stamped X-pipe and a 2.5" midpipe.
Old May 6, 2008 | 09:14 PM
75 Stingray!'s Avatar
75 Stingray!
My Catera has an oil leak so I’ll be swapping in a V8
In my many hrs of researching cams for my LS1, looking at cam only (+ Bolton mods) Dynos I noticed the same results as Arun has pointed out. The LG make great power under the curve and would make an excellent street header. The AR often got the best peak power buy have a strange drop in the midrange. I figure if you’re on the drag strip you're never in the midrange.
I'm not saying anything bad against any of the headers they all have their strengths, it's up to you what you want most.
Good luck with your new exhaust
Old May 6, 2008 | 09:53 PM
sami85L98's Avatar
sami85L98
If u r not making or dont have plan to go over 450 Rwhp than LG pro are just waste, Street is the way to go, they might look small but u be surprised when u get it, ofcourse Pro's are good to have but at cost of 500 bucks over? eek. Manny got dam good price on these.
Old May 6, 2008 | 10:02 PM
sami85L98's Avatar
sami85L98
Manny,
FRC ken: i saw both headers pro and street in person, when i met manny last weekend, the only 2 major difference is merge Collector's on Pro are little longer may be an inch or 2 and mid pipe is 3" all the way to Catback muffler pipes, and also Pro's X-pipe are joined together and welded, where as Street X-pipes are Crossed welded and 2 1/2" size, other than they both are identical.
Old May 6, 2008 | 10:15 PM
1%r's Avatar
1%r
St. Jude 15 Year Donor
St. Jude Donor '03 through '17
The only headers that I run on my car are cast iron log type turbo headers.
To Check Engine Light
