Column Lock Bypass in Alberta?
![](/forums/images/ranks/1k-2k.gif)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Has anyone had it done or found a supplier for the parts? Has anyone had CL tuned out, and if so who did it? The F***ing recall removes the lock but gives you fuel cut.
![Mad](https://www.corvetteforum.com/forums/images/smilies/mad5.gif)
![](/forums/images/ranks/3k-4k.gif)
I just went through it..
Corvette of Houston...aka COH sells a column lock bypass.....
Price $49.00
Had it installed at my dealer last week...no problems since !
Price $49.00
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
Thanks Bubba but I have a date with a dyno on Thursday so I am hooped if I have to import from Texas. Was hoping there was a distributer in Alberta. If I am lucky the tuner has a new enough version of HP that he can delete the CL but the reason the car is getting dyno work is for exhaust work that needs to be done before it goes there. If I miss this appt I am waiting for another 2-3 weeks and I can't do the exhaust work if it isn't driveable. This is my third C5 and it is the first time I can say that I am truly disappointed with a build quality issue. The GM steering lock recall is a half assed cheapskate effort.
When the column lock error occurs, your car will not do more than 2mph. When it does, the fuel cuts and you stall. I had the recall done, so no locking steering wheel, but it just spontaneously errored me while I was trying to pul it into the garage.
