Portable tire kit pump?!
![](/forums/images/ranks/5k-6k.gif)
2021 C6 of the Year Finalist - Modified
![](https://www.corvetteforum.com/forums/images/ranks/cf15.jpg)
![Default](https://www.corvetteforum.com/forums/images/icons/icon1.gif)
Hey buds.
Been running non run-flats for a while, I know I really should get a small tire fix/compressor. Want one that will fit in one of the compartments in my trunk.
Seen a few brands at crappy tire and lots on the internet. Anyone know a decent one? Or any to stay away from? I also don't want to spend a zillion dollars on one just because it has a Corvette logo on it.
![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
![](/forums/images/ranks/7k-10k.gif)
Hey Corrado,
The pumps are pretty much a commodity now - so most brands will do - (Cdn Tire) places them on sale pretty frequently.
I carry a compressor and can of tire fill, but I recently read that the tire fill can screw up the Tire Pressure Sender if you use it - it basically gums up the sensor and could result in your needing to replace it. So I also purchased a tire plug kit - one of those old fashioned tools where you insert a plug from the outside - the way shops used to repair tires. A plug will easily get you to a facility where a full repair can be installed from the inside of the tire.
Jack
Jack
![](/forums/images/ranks/3k-4k.gif)
Jack
Jack
![](/forums/images/ranks/100-500.gif)
Hey buds.
Seen a few brands at crappy tire and lots on the internet. Anyone know a decent one? Or any to stay away from? I also don't want to spend a zillion dollars on one just because it has a Corvette logo on it.![*****](https://www.corvetteforum.com/forums/images/smilies/willy_nilly.gif)
I use a basic compressor I bought from Cdn Tire. The kind that has a pressure gauge and plugs into your cigarette lighter. I think it cost me around $10.
A few years ago, I had a flat on a fairly remote stretch of highway. It was getting dark, not a car in sight for hours and after slapping on my donut, I realized that it had no air.
No problem, I thought. I took out my compressor, plugged it into the lighter receptacle only to realize that my lighter port was dead! (Never had to use it before on my beater.)
I suddenly felt a little concerned... thinking that I might have to spend the night in my car when I was hit by a sudden burst of brilliance. I figured that I'd tap my battery! Out came the jumper cables as I carefully attached the large clamps to the male connector on the compressor and the other end to my battery.
Worked like a charm!
Ok... this is off topic but I'm bored at work...
![Thumbs Up](https://www.corvetteforum.com/forums/images/smilies/thumbsup.gif)
![](/forums/images/ranks/4k-5k.gif)
Good idea about the soapy water, I never would have thought of that. I have a patch/plug kit in my garage, not much use there if I have a flat on the road, and I have a portable inflater on my boat for water toys - not much good there if I have a flat .... I may have to re-think this whole thing!!!
Only problem I can see, is that the portable inflater I have, works so slow and poorly, I think I'll try to find something better.....
Oh, and I'm bored at work too... I think I'll go to Port Dover it's Friday 13th....
if anybody else decides to go to Dover, stop by my boat at the city marina, look for "THE FOG DUCKER".....
Flat tire...doesn't my Gold CAA card cover that
I have a portable compressor from Canadian Tire & can of tire inflator...in my garage too...
lauri
![ROFL](https://www.corvetteforum.com/forums/images/smilies/rofl.gif)
![Big Grin](https://www.corvetteforum.com/forums/images/smilies/biggrin5.gif)
lauri
1 Post
Now I'm thinkin I'm glad I've got the aformentioned kit cause it looks like I may need it. OH CRAP! It's all at home on my work bench.
Anyway, I get to the Hwy 88 cutoff headin for the truck stop for the much needed air, and get stopped by a cop for a seatbelt check. OMG, I'm not wearin it! In my haste to get down the road I didn't put it on. Fortunately, he was lookin the other way talking to a truck driver and I managed to fumble it on. He says to me "Just doin a seatbelt check sir" to which I replied "Thank you officer, I always wear mine"
![Smile](https://www.corvetteforum.com/forums/images/smilies/smile5.gif)
Anyway, the rest of the trip home was uneventful. I learned 2 things from this experience:
1) Never believe everything your DIC tells you, and
2) Keep the kit in the trunk
Dave
