headlights
Sep 16, 2010 | 06:44 PM
headlights
How can we stop the headlights from coming on automatically? I have a 1998 C5. I just want to turn them on manually!
Sep 16, 2010 | 06:48 PM
you have to pull a fuse I think its 44
Sep 16, 2010 | 07:01 PM
Will this effect anything else? Is this #44 fuse under the hood or under the dash?
Sep 16, 2010 | 07:07 PM
Quote:
Originally Posted by
Cdn UFO
I thought the fuse pull only works with 2000 and newer.
Sep 16, 2010 | 07:09 PM
Its relay # 44 located behind the removable carpet piece at the front of the passenger foot well.
This will not effect any other functions.
You will now have to turn your headlights manually.
Sep 16, 2010 | 07:10 PM
Sep 16, 2010 | 07:11 PM
Zeeman28a
Didn't know that. It worked on my 2002.
Sep 16, 2010 | 07:13 PM
Sorry for the repeat in question! Thanks for the answer i will give it a try tomorrow.
Sep 16, 2010 | 07:14 PM
harleyvette
If you have the US based C5, you can turn them off with the Twilight Sentinel option in the DIC as well.
Sep 16, 2010 | 08:19 PM
Zeeman28a
Yup, that's what I do. Sometimes though I wonder why it's so dark out and then I remember to turn them on.
Didn't know until recently it was US only. Goes back to me thinking GM thinks Americans are smarter than us Canucks and can handle headlights on their own.
Sep 16, 2010 | 08:32 PM
Overdrive
If only it was GM. Just another form of goverment thinking they know what's best for it's citizens.
Sep 16, 2010 | 08:41 PM
[QUOTE Goes back to me thinking GM thinks Americans are smarter than us Canucks and can handle headlights on their own.[/QUOTE]
GM knows Americans are smarter...thats why they sell the vett here...for 15-20% more.
Some of us have caught on thou
Sep 16, 2010 | 09:36 PM
St. Jude Donor '08
check out "corvettegadgetman"..he has a simple headlight defeat resistor that works like a charm...5 min install....
Sep 16, 2010 | 10:41 PM
removing that relay 44 worked great for me on my 01
Sep 19, 2010 | 09:45 PM
Hey guys, i tried that #44 relay it did not work! My manual says #52 is the maxi curcuit breaker-headlamps, i tried this relay it does not work. Remember i have a 1998 C5.
Sep 19, 2010 | 09:47 PM
You can add a resistor to the sensor on top to the dash. I did this on my '00.
Sep 20, 2010 | 05:49 AM
HiVoltge
Where can i contact corvettegadgetman to get this relay?
Sep 20, 2010 | 10:51 AM
St. Jude Donor '08
harleyvette
try "corvettegadgetman.com"...
Sep 20, 2010 | 09:14 PM
Thanks for the info. I will order one. If there are any others that need this part let me know a group order is quite a bit less in cost.
