Canadian Events Canada, eh?
Breaks, breaks, breaks
Old Mar 9, 2011 | 03:35 PM
940CACC's Avatar
940CACC
Default Breaks, breaks, breaks
I should have went with the Z51 and didn't but that's 3 years ago and my 2008 coupe has changed considerably...Vararam, Billy Boats and LG long tubes.
It's not so much for the extra stopping power...the rotars are just too small. I track the car 5-6 times a year and that's about it so I'm not looking to spend thousands on a full break upgrade.
Does a simple upgrade to the Z51 breaks with ceramic bads make sense or should I really spend the extra for a bigger set.
Old Mar 9, 2011 | 03:55 PM
1BDRSK's Avatar
1BDRSK
Do you have brake ducts installed? They will help your brakes last longer. Honestly I researched this and decided it was cheaper to stay with stock rotors and just replace them once or twice a year. Plus I went with a fairly agressive Carbo Tech pad and have good stopping power. Since you don't have the Z51 set up, you have more options for rotors at a decent price.
If your wheels will allow it, upgrade to a used Z06 set up, that will make a difference without braking the bank.
Old Mar 9, 2011 | 07:34 PM
tlaselva's Avatar
tlaselva
That'd be my suggestion. Go with Z06 setup. Best bang for the buck.
Old Mar 9, 2011 | 08:34 PM
Corvette.Lover's Avatar
Corvette.Lover
Brakes and rotors...have a nice day.
Old Mar 9, 2011 | 09:00 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Old Mar 10, 2011 | 10:15 AM
940CACC's Avatar
940CACC
Originally Posted by 7t2vette
Thanks for the spell check
Old Mar 10, 2011 | 11:49 AM
C6Vette2009's Avatar
C6Vette2009
Here's a thought! Buy a used z51 suspension package and a Eradi Speed brake kit for a Z51 package. Why? Because you won't have to change you're stock rims and the Eradi Speed upgrade brake package will give you better braking [ and looks great - really fills out the rims] at a fraction of the cost.
Now, I have to give you some back ground on my statement. I have an 09 C6 AT, with both the Z51 package [from the factory - original equipment] and the upgraded Eradi Speed brake kit. I'm upgrading to the C6Z system, Pfadt and LG suspension set-up at the end of this month. Hence, I will have available for sale, if your interested, the sways for the Z51, the Eradi Speed brake kit and a set of Bilstein shocks [2 used and 2 new].
Old Mar 10, 2011 | 12:12 PM
Sherminator's Avatar
Sherminator
This is a customers add for the brakes I just took off to go bigger. This is the Baer Eradispeed setup for a C6 Z51 with the big 14" rotor in the rear.
http://calgary.kijiji.ca/c-cars-vehi...AdIdZ265555187
Old Mar 10, 2011 | 02:46 PM
Snobike Mike's Avatar
Snobike Mike
If you are worried about your brakes breaking then you definately upgrade your brakes before they break, cause once they are broken you won't be able to use your brakes.
Old Mar 10, 2011 | 08:05 PM
lionelhutz's Avatar
lionelhutz
"ceramic bads"
Yes, ceramic pads are very bad for a performance braking application.
Try cheap new rotors and some aggressive racing pads for the track before dumping a bunch more money into upgrading the brakes.
Peter
Old Mar 11, 2011 | 12:56 PM
940CACC's Avatar
940CACC
Thanks...PM sent
To Breaks, breaks, breaks
