Canadian Events Canada, eh?
Alignment C6
Old Apr 28, 2011 | 03:27 PM
nubrand's Avatar
nubrand
Default Alignment C6
Whats the price of a good alignment on a c6?....and is there one shop that knows these cars better then the next. I will lower the car on stock bolts only.
I would like to have it aligned, for less tire wear....not concerned about tracking the car.
Im in the Hamilton area, but would travel anywhere in the GTA.
Old Apr 28, 2011 | 03:31 PM
dankhts's Avatar
dankhts
I've recently used Dream Tire in Burlington, Rod's a forum member...
http://www.dreamtire.com/
Old Apr 28, 2011 | 09:20 PM
Cap'n Pete's Avatar
Cap'n Pete
In that area, go to Can-Alignment (Scott). He setup my car (2010 coupe) last year to work well on the track (which it does) with about -1° to -1.5° camber (nothing crazy) but be reasonable for street wear. The car tracks perfectly straight on the road (way better than my '02 Camaro EVER did) and corners nicely on the track. Also lowered on stock bolts. Reasonable price (depending what "reasonable" is to you).
http://www.canalignment.com/contactus.htm
Old May 1, 2011 | 04:24 PM
nubrand's Avatar
nubrand
Thanks guys...I will check both of them out.
Old May 1, 2011 | 05:23 PM
CanadaGrant's Avatar
CanadaGrant
Corvettes are notorious for alignment issues right from the factory. They might steer in the right direction when you let go of the wheel, but inside fronts will wear out quickly and tire costs can mount up in a hurry. If I buy a new one the first thing I do is ask or an alignment. They think I'm crazy until they see it on the rack.
GM cares about their products but feels tire wear isn't their responsibility even if it is caused by their lack of workmanship and Goodyear will tell you to take a hike.
$150 should get you a really nice 4 wheel alignment.
Old May 1, 2011 | 09:15 PM
RonJ's Avatar
RonJ
That inside tire wear is too much negative camber for the mostly straight line driving you do. When the car is on the alignment rack, find out how much negative it's running and then reduce it. One degree negative is more than enough for street use. Sure makes a difference in tire wear.
RonJ ...
Old May 1, 2011 | 10:59 PM
FireRoc's Avatar
FireRoc
RonJ ...
Agree that 1 degree negative is enough to cause inside tire wear. When I had a 1990 300 ZX that was the spec (front and rear) and it wore the tires on the inside more than on the outside.
When I had a 98 Trans Am, I ran it at about 0.5 deg negative and it wore the tires well. Remember that proper wheel alignment is a combination of three settings (camber, caster and toe), and if you deviate from factory with one, you "may" have to also change the other two to get proper tracking and handling.
I haven't looked at the C6 settings (yet) to see what I will run when I get a wheel alignment. So far my tires are wearing okay, and the car drives really well on the street.
I suspect, I will be getting into this later this summer when I have to replace the KDW2s (which I am not very happy with).
Old May 4, 2011 | 05:13 PM
Cap'n Pete's Avatar
Cap'n Pete
Guess I should have mentioned that I was NOT concerned too much with tire wear when having the alignment set at -1.5° camber!
To Alignment C6
