Canadian Events Canada, eh?
Nitrogen
Old May 25, 2011 | 10:23 PM
martinf55's Avatar
martinf55
Default Nitrogen
First, nitrogen in tires, now Shell has nitrogen in their gas. They claim less buildup of carbon deposits, gunk and makes your engine run clean. Better than the rest? Hmmm.
Old May 26, 2011 | 12:04 AM
TGstring's Avatar
TGstring
From: cruising between USA and Canada... SAVE THE WAVE!
Hocus pocus.
I heard that the only reason they put any "additives" in gasoline is to differentiate it from the competitors; that means, it's all the same basic gas, with drops of this or that in it to make it easier to pick out when pumping it into the trucks.
There's not enough of anything in there to warrant the claims...it's all marketing.
At least, that has been the US perspective.... I can't see the Canadian side being that much different.
Old May 26, 2011 | 01:17 AM
tfi racing's Avatar
tfi racing
They do nothing but lie to us about BS such as "market forces","speculators",and"refinery issues" to justify their endless gouging at the pump,why be stupid enough to believe anything else they say?
As for the nitrogen in the tires,if you spend any time on the track,you will see a benefit there,for street use,its just more useless hot air...
Old May 26, 2011 | 08:27 AM
Overdrive's Avatar
Overdrive
Yeah, what's next? Soon we'll hear there's nitrogen in the air we breath!
Old May 26, 2011 | 09:01 AM
imp zog's Avatar
imp zog
78% of the air you pump into tires is nitrogen, so in theory if the justification is that it's the oxygen that leaks out, after filling up any pressure loss, you will eventually have namely nitrogen inside anyway. It is bunk the way it is marketed.
The true benefit of nitrogen is simply this: it contains almost no water when put into the cylinders at 3000psi. In normal street use tires, you will never get them hot enough to turn any moisture inside your tires into a significant amount of vapor (and hence an increase in vapor pressure). We had to switch to nitrogen on my bias slicks because bias tires like to balloon out when the pressures build, and you lose the nice flat contact patch that you want for grip. This was specifically to make sure that the tires did not contain excess humidity that would have gotten pumped in from an air compressor. I put a big desiccant tube (filled with moisture absorbing pellets) in-line with my home compressor for this and air tools that are sensitive to moisture. (and there is a LOT of moisture in that air, just open the drain valve on the bottom of a compressor!)
Old May 26, 2011 | 10:03 AM
NOCRISIS's Avatar
NOCRISIS
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
cause and effect,,,without the effect,,,
Old May 26, 2011 | 10:30 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
anything at all to take more money from us. Ron
To Nitrogen
