Canadian Events Canada, eh?
WTB cannot remember
Old Apr 22, 2013 | 09:58 PM
harleyvette's Avatar
harleyvette
Default WTB cannot remember
I want to buy the switch where you can turn the head lights on and off manually on the Canadian C5's. It was advertised awhile back but I forget by who.
Old Apr 23, 2013 | 01:10 AM
lionelhutz's Avatar
lionelhutz
You mean defeat the twilight sentinel or keep them from coming on at night or in a building?
Depending on the year of the car you could have a few options.
Earlier models (up to around 2000) you can pull the sensor in the center vent of the dash and remove the wires and put about a 5k resistor on the wires instead. I don't know the exact year but the early Canadian cars were fixed and this is the only way to defeat it.
Later models you could do the same thing or find someone with a techII and turn off the export setting which should make a twilight sentinel setting in the options on the DIC appear so you can select which way you want it. If you are interested in this I could check the manuals and see when the BCM option became available to set this. The only part I don't know is if changing this would do something like default the car to miles when you start it.
If the car was imported then it should already have a setting in the options of the DIC to turn it off.
If you search the C5 tech forum for defeating the twilight sentinel you should find lots of info.
Old Apr 23, 2013 | 11:37 AM
Cdn UFO's Avatar
Cdn UFO
. C4 and C5 Auto Headlight DEFEAT (1990-2004 models) - manual conversion device for Canadian C5 Corvettes
see: corvette gadgetman
Old Apr 23, 2013 | 11:38 AM
Cdn UFO's Avatar
Cdn UFO
www.corvettegadgetman.com
Old Apr 23, 2013 | 11:50 AM
islandman's Avatar
islandman
I think you can pull the #44 relay,thats what I did
Old Apr 23, 2013 | 12:53 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by Cdn UFO
$18 for a 2 cent resistor. Seriously?
Old Apr 23, 2013 | 03:28 PM
Cdn UFO's Avatar
Cdn UFO
I can lend you the money
Old Apr 23, 2013 | 05:37 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Old Apr 23, 2013 | 05:52 PM
harleyvette
Thanks guys for the info.
Sweet 90's Avatar
Sweet 90
Buy a 100 ohm resister and place it in parallel on the light sensor wires. This works in the C4, and if like they say it's universal, it should also work in the C5.
Old Apr 23, 2013 | 10:50 PM
ontcanuck's Avatar
ontcanuck
just pull the fuse that's what I did worked great
Old Apr 23, 2013 | 10:53 PM
ontcanuck's Avatar
ontcanuck
Islandman is right If you have a Canadian C5, and you keep it in your garage as I do, every time you start the car, your headlights pop up. As you know, the gear in the headlight motor is prone to failure as one of mine did. On the Cdn car, you cannot bypass this event on the DIC (U.S. cars you can). 99 times out of 100, I don't need my headlights, thus the premature failure of this gear.
OK, here's the work around. Remove relay # 44 in the passenger footwell fuse box (see details of location in the manual). I did this in 5 minutes. The only downside is that you have to turn your headlights on yourself. Oh, thats not a downside at all!
Old Apr 24, 2013 | 05:43 AM
OBSESHON Mark's Avatar
OBSESHON Mark
Thats all I did, and have done it on a few other members Vettes also.
Old Apr 24, 2013 | 07:49 AM
4 KRUSIN's Avatar
4 KRUSIN
Yep, that's the fix. I had one gear fail before I found that fix. Now I can control when the lights come on.
Old Apr 24, 2013 | 09:21 AM
harleyvette
This does not work on a 98 C5. I and others have tried.
Old Apr 24, 2013 | 04:38 PM
oakvillec5's Avatar
oakvillec5
wow, I have a 98 USA convertible, I never knew that CDN car's lights pop up in the dark when started.
Old Apr 24, 2013 | 05:46 PM
Zeeman28a's Avatar
Zeeman28a
This applies to Canadian cars only. The fuse thing only works with 2001 and up I believe. In your case, you have to go the resistor route.
Twilight sentinel can be turned on and off using the D.I.C in all U.S. based cars.
To WTB cannot remember
lionelhutz's Avatar
lionelhutz
My understanding is the relay 44 trick doesn't stop the car from turning the other lights on. It just cuts out the auto power to the headlights.
Old Apr 24, 2013 | 06:02 PM
harleyvette
Yes that is correct.
Old Apr 24, 2013 | 06:04 PM
Zeeman28a's Avatar
Zeeman28a
Disables the motors. Your lights will still come on. Correct. Kinda weird looking at the front of the car with the lights pointed down. I didn't like that in my '03 so I left the fuse in.
Kinda of miss the pop ups now in my '05 but at the same time glad I don't have to worry about the plastic gears.
