Rivnuts question
did my due dilegence and did a search on the forums and googleized it also.
Thanks Al
http://www.princessauto.com/en/detai...it/A-p8514234e
http://www.princessauto.com/en/detai...it/A-p2925204e
Watch this:
Watch this:
thanks for your input tho Bruce
Al
If you can't use the tool because of location or don't have one - the biggest challenge is preventing the rivnut/nutsert from turning on the mandrel bolt when you are trying to tighten the nut to collapse the nutsert - pretty hard to do.
You can try pushing the nutsert against the metal you're trying to install it into - good luck with that.
I recently had a similar situation (I couldn't get the nutsert tool into a tight space) but was able to clamp some vice-grips on the back of the nutsert locking it onto the threaded mandrel (bolt).
You can try to pre-expand the nuserts/rivnuts slightly and see if you can get enough of an interference fit to drive them so they don't turn.
Lots of grease , multiple washers under the nut and you may be able to "pull" them in (expand them).
Depends on the "backing" mat'l strength - you could even Loctite the nutsert (with low strength loctite) to the mandrel and then break it loose after the rivnut is fully installed ?
Going into a hex hole that could work okay ?!
If you're doing more than one nutsert - and if you can use the tool - don't fight it get the tool (hand / manual one not pneumatic).
They are pretty cheap compared to the aggravation it'll save you.
Brilliant one old limey to another ! LOL
Just have to remember for next time LOL
Amazing these computers and You Tube LOL
I got some but to far !
