Anyone know a pool guy...Scarborough area
Thought I would ask...
My pool pump is fried and I need to get a new one installed. Would do it myself but no time. Will need an electrical hook up as I feel for the variable speed energy savings (supposed to pay for itself in 2 seasons). It needs to be hard wired vs a plug in.
Thanks for any referrals.
If the pool pump is dead you will need a new one but if it's just making a lot of noise it could be the bearings are going bad. Had this happen to my pool pump in Tucson and was able to get new bearing installed for a less then $200. Much cheaper than a new one motor. Good luck with the change and enjoy the pool when it's back in operation.
A timer on the pump will save more than variable speed. We found that about 7-8 hours a day is more than enough running time on the pump. Slowing down a pump hurts the mechanical efficiency of the water pump. So, as an example, you might be able to slow it down so you only pay 1/2 the electricity costs. But the pump might only be moving 1/4 of the water.
Toronto Hydro is offering a significant rebate on variable speed and I took advantage of it. For the net nominal extra, I liked the built in timer, ability to control speed at any point of the day and with constant circulation through the heater, avoidance of superheating the heater connections when the pump would go off. Just a preference...will see how it goes.
As with most things, its an equation of options, compromises and cost...
