Electrical Issues On My 2006 C6 Vert
Good morning everyone.
looking for some help with electrical issues.
Last Friday evening I stopped for gas and a bunch of things happened.
1st: Could not open the door.
2nd: Power windows won't work
3rd: Convertible top will not go up or down
4th: Power locks won't work
5th: Power gas door won't open
6th: Power trunk does not work.
I installed a new AC Delco battery yesterday, which did not solve any issues.
The car will start and run, but all of these other issues, have me stumped.
Has anyone ever run into these type of problems?
Thanks in advance for any help.
What state are you in?
Any mods?
First thing would be to get codes?
If your in conn. Or near try Jackson Chevy in Middletown Ct. best corvette tech in my opinion ..he is also on Facebook as I believe the corvettemechanic
Any mods?
I encounter similar issues with my '05 once in a while. It's like the FOB doesn't work to open the doors, open the trunk, although I've never had the power top or windows not work.
Strange really though. I have to use the key to open the trunk to open the driver door. Once that is done, the FOB miraculously starts working again. Even the button under the dash to open the trunk won't work sometimes, but as soon as I open it with the key, it all starts working again. I figure it's one of those first year gremlins or the many wifi **** in our air that interferes or whatever. Since removing my dash cam and dash mounted NAV unit, no more FOB not detected errors though.
Hey Mark.
Crazy electrical problems.??
Last week I had the traction control code pop up a couple of times.
If you had the traction control code come up, I suggest you invest in buying the connector reinforcement part from GM and inserting into the connector under the steering column. A cheap investment that can't hurt
Traction Control thread has picture and part number...
https://www.corvetteforum.com/forums...light=traction
Mark if the partition in the trunk is not on properly and not making the end switch the roof will not do anything. I dont know if it affects the other stuff put have a look it is making the switch.
Also don't forget to Re Index the windows by holding the power switches up for 3 sec when you have this solved.
Steve
Steve
Steve
Steve
Steve
Steve
Al, that was very mean.
Mark, any luck sorting the issues out yet? Electrical/electronic issue have to some of the most frustrating.
Good luck.
Good luck.
