I did a review on it when I got it and used it a few times, later today I'll find it and link it here. Generally I like it and much better than jack and jackstands. The lift frames are god awful heavy to move around though and there is enough space under the car to position the small blocks but I like some space under there so when I can I put the front of my car on my homemade ramps and makes it easier to put the frames in place with tall blocks and jacking pucks.
I've had no leaks, no issues that were the fault of the unit (1 time user error on me). The early models had problems with leaking hoses the later ones are better and it also comes to user install when putting it together and periodic maintenance.
The 7000 frames are slightly taller than 5000 frames. I've never lowered my cars and on the C6Z with the jacking pucks in place with short blocks it will just barely slide under. With the ZR1 now again jacking pucks in place short blocks the LF side puck lightly rubs the short blocks as I slide the frame in place. What I do now is on that spot I get the block in place (and it might be right under the puck or slightly off) + the other 3 areas lift up the car like an inch or two and lower back down then I check all the blocks and now the car is slightly higher than when it is sitting on the wheels.
I have the 5000, pucks in car, and leave a 2x6 piece of wood in the trays, no rubber blocks will work, slide it under and up we go.
I paid this Costco price for my 5000 a few yrs ago.. definitely a good deal
You can buy a Kwik lift for that price and no hoses will leak all over the floor and it is safer to! Quick Jack is a waiting hose to leak!
I have a 5000 model, no leaks ever and the Quickjack only uses the hydraulics to lift the car, not “hold” it once elevated. There are steel support rods that seat against steel rests in the frame to hold the car off the ground. The hoses do not leak, they have dust caps to keep them clean and if you hold the down button a few extra seconds there is no pressure in the lines and the quick couplers are very easy to connect/disconnect.
Edit: As far as “safer” there’s a YouTube vid where they load a Quickjack with over 16,000 pounds, no fail...about 5 of my Z06s.
And i still put stands under it, just in case something goes sideways.
