No fob - off or run
08-17-2023, 01:15 PM
Toronto Events Coordinator
No fob - off or run
Any ideas, just before a road trip and its got me nervous...
08-17-2023, 08:52 PM
From memory these cars do this if you turn off the ignition without having your foot on the brake. Was that the case?
08-17-2023, 08:59 PM
Did you try it in the slot in the glove box?
08-18-2023, 09:17 AM
2021 C6 of the Year Finalist - Modified
Highly recommend changing the FOB battery ASAP, make sure it's a good brand name 2032 Battery. Also, try Fob 2.
08-18-2023, 10:36 AM
I had the same issue, change the battery in the fob.
08-19-2023, 06:04 PM
The first thing I did was change the battery FOB, tried both remotes, tried the fob in glove box procedure....nothing helps
