HELP!!! Wife just "dusted" my car!!!
Help, this is an emergency! My wife, trying to do the right thing, just dusted my entire car with a DRY, LEATHER CHAMOIS. As you can imagine, the black paint is now FILLED with scratches. What should I do?
Location: Ponte Vedra Beach / London State: Dazed and confused
Try the MILDEST polish you have and see if that works (Megs ScratchX with a very light pressure applied?)
Let us knw how it turns out...and don't be too hard on yout wife, she thought it was helping you...
JonM
JonM
St. Jude Donor '03
Originally Posted by jabez
Go give her a hug. I am sure she feels bad enough already.
Go drive it really fast to put the scratches in perspective!
I just washed mine a found a couple of really tiny "dings" - I keep telling myself "It's a machine, it's not a puppy - it will be alright".
I'm sure you will find some good advice on this forum on how to get the scratches removed - good luck.
Okay, there are a couple of options. The best option is to have the car buffed with swirl mark remover. All will be perfect again. The second requires much more elbow grease. 3M makes a product called finish restorer also Meguiars makes something called Body Scrub. Both products will remove those scratches, 3M may have replaced the finish restorer with their cleaner wax. If you do it by hand you will probably look like Gov. Arnold. But it will work.
1 Post
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Tough call...Start with a wash 7 see how bad it is...3M swirl remover might work or it may need to be power polished. Depending on your comfort level you can easily do it yourself but it's a MAJOR job.
Former Vendor
Would it help to put another layer of wax on....or do I need to do the polish first?
Oh almost forgot, teach your wife to use this, no scratches and no dust. http://www.autogeek.net/oxo580.html
If you are a perfectionist like me you will probably want to polish them out first. If you have a Porter Cable randon orbital you are in luck, if not it can probably be done by hand as well (just more work). Use a product like Menzerna FPII or 3M ssr 39009 with either a foam polishing pad or 100% cotton cloth (by hand) If by hand rub in straight lines not circles and do a small area at a time. After you have the finish where you want it finish up with Zaino Z5 followed by a coat of Z2 Pro (following Zaino's directions of course) or with a product of your choice. I have black and can not live without Zaino products.
And do not go too hard on your wife, she WAS trying to help. Maybe do like I do and get her involved and teach her the right way.
Location: You should have told him it would not hit 185 if you dropped it out of the back of a C130 with 4 heffalumps inside trying to get to the Golden Corral.
