Clay Bar or Not?
Clay Bar or Not?
I am debating whether or not to clay bar my black 02 or not. I am using Menzerna Polishes to correct the finish. Should I clay before the Intensive Polish or will the IP clean the paint for me?
I clayed my 04 last year 2 weeks after I got it home.... dirtiest clay I've ever seen. In other words... CLAY your car.
Go here: http://www.bettercarcare.com/articles.php?articleId=14
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Clay your car....the worst that could happen is that you waste a little time. Chances are you will find it is something that should be done often and will give great results.
Very esy to use follow the instructions
Clay the car but don't waste your money on a clay lube nor use a detailers spray. Take a 32oz spray bottle, fill it with water and add a few drops of car soap. Use this as your clay lube.
Many pros like to rotary buff the finish first and then they clay. Then finish polishing.
Also no need to wash the car, dry the car, then wash the car again after claying. JUst wash the car and then while the car is still wet from rinsing use your homemade clay spray and clay the car. Rinse as you go along.
Anthony
Anthony
