Removing Bugs
What's the best (and safest) product/method to use for removing bugs off the paint? After driving a few hours to a show (or anywhere else in the Summertime), the nose of the car has a million bugs splattered on it. You can't wash your car when you get there. Who can tell me what they use?
I heard of someone using 'shrink wrap' around the nose.
Thats the clear wrap they use to secure boxes on a pallet.
I never did this, but it makes sense if you have to drive thru a million bugs to get to a show.
First off keep a good covering of polish & wax on the paint. Then just spray the area with some quick detailer and wipe them off.
If they are particularly dense in the are into which you are driving you might could leave a thin film of un-buffed wax on the nose. Then it will be even easier to wipe them off with quick detailer.
Originally Posted by Mikez40
WD-40 works great for removing bugs.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Number one question to all you kerosene and wd40 users:
If you can't wash your car (see original post), how do you then remove the kerosene and WD40???
Number two question:
And would not those two very fine solvents also remove any wax that you have so carefully applied to your car's fine paint??
(I think if I were in this situation, I'd just take 3 gallons of distilled water and a little car wash soap...along with a spray bottle...with me to the show and carefully wash the little squashed buggers off...then use detailer on the paint)
Larry
code5coupe
Larry
code5coupe
Larry
code5coupe
Larry
code5coupe
if the bug residue bothers you then the Pam thing is the easiest to work with. Wipes right off w/detailer. But even w/o Pam, the bugs stuff will come off with detailer and a little elbow grease. Just one of the joys of summertime driving
ps, glad to hear you DRIVE it!!
Meguiars quick detailer mist and wipe plus a nice cotton towell and you should take them right off if your have a good wax underneath.
The sooner you get to it the better off it will be.
Originally Posted by ozvette
Agreed 100%
Originally Posted by sts57c5
I use some stuff called bug away - i just spray it on wash with a bug mitt and they come off real real easy.
St. Jude Donor '03-'26
Meguiars sells a "Tar and Bug Remover". Spray it on let it sit for several seconds and wipe it off. Works well for me. I just applied Rejex so I'll see if bugs "stick" to the front end anymore.
