Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Will clay bar do it?
Old May 13, 2005 | 07:07 PM
Dark-Knight's Avatar
Dark-Knight
Default Will clay bar do it?
While driving today my car was over sprayed by what appears to be white wash of some sort. No way I could have avoided it.
The stuff came off the body of the car easily, but the nose and side mirrors, windsheild too, have remnants that can be seen and felt when you look close.
Will a clay bar get the suff off? I've not used a clay bar before so your input will be helpful. Assume I have to wax after the clay bar.
Thanks gang!
Old May 13, 2005 | 08:14 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
I'd sure bet it will!
I've clayed my windshield before too. Just keep everything well lubricated so it doesn't drag on the surface.
Old May 13, 2005 | 08:15 PM
jrose7004's Avatar
jrose7004
I've claybared oversprat from my chrome wheel and windows!
Old May 14, 2005 | 08:16 AM
rws.1's Avatar
rws.1
Clay bar was originally designed to remove overspray.
It will remove most imbedded contaminants on your paint.
It will not take out scratches or swirls or spiderwebs.
Old May 14, 2005 | 12:54 PM
DaBoz's Avatar
DaBoz
This may be helpful:
http://www.bettercarcare.com/articles.php?articleId=14
Old May 14, 2005 | 11:05 PM
plmkrzy's Avatar
plmkrzy
Clay Bar will do it! I clayed my '94 that I thought was almost perfect before. Now I just can't believe it. The shine is much deeper and "cleaner" looking. Clay takes just about anything off. Tree sap, paint overspray, road tar, bird droppings, bugs etc.
Try it, you'll like it I'm sure.
Old May 14, 2005 | 11:35 PM
VETFVER's Avatar
VETFVER
If a clay bar does not do it, I would use turpentine to remove it. Go over it with at damp cloth and rewax if it was on paint. For the glass, I would use a good glass cleaner when you are done. Turpentine will not harm your paint or your glass.
Dan
Old May 15, 2005 | 09:09 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
A good claybar should remove most to all of the damage, very similar to removing overspray. That said, you might need to also use a slightly abrasive polish in order to remove any stubborn marks. It is however easily repaired at home.
To Will clay bar do it?
