Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Tree Sap
Old Jun 13, 2005 | 07:11 PM
NSTY C5's Avatar
NSTY C5
Default Tree Sap
What's the best (safe) product to remove tree sap from a black C-5?
Thanks, Mike
Old Jun 13, 2005 | 09:50 PM
KLO's Avatar
KLO
Assuming simple car wash will not remove it, try a clay bar....
Old Jun 14, 2005 | 01:41 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
Mule ****.....Works wonders. Really.
Old Jun 14, 2005 | 01:55 PM
JOHN MOORE's Avatar
JOHN MOORE
Thanks, Mike
if the sap has not had time to harden, a little windex on a towel will work...if the sap is hardened, and is not a thick drop, any brand of bug and tar remover (i use turtle wax brand) will usually work...if it is a larger glob of sap and the bug/tar remover won't get it off, a little 3m adhesive remover will usually get it off....
Old Jun 14, 2005 | 04:03 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
WD-40 to loosen it and remove then if it has etched then follow with ScratchX
Old Jun 15, 2005 | 01:16 PM
CrashNBurN's Avatar
CrashNBurN
This is a good trick, just don't let the WD-40 sit longer than 40 seconds or so. Do not use any abrasive polish or compounds. If you use a product that contains abrasives you will put swirls and fine scratches
in your paint finish.
Old Jun 15, 2005 | 04:04 PM
Sleper's Avatar
Sleper
Old Jun 15, 2005 | 07:34 PM
VETFVER's Avatar
VETFVER
Goo Gone works on just about everything. No car care garage is complete without it.
VETFVER
Old Jun 24, 2005 | 12:42 PM
nutseynut7's Avatar
nutseynut7
Default tree sap
heres a strange remedy cold water Wash with plain cold water worked great for me
To Tree Sap
