Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Random Orbital Buffer
Old Jun 21, 2005 | 09:56 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
Default Random Orbital Buffer
Want to wax the 04 Vert with NXT.
I have a Sears Random Orbital Buffer which is probably 15 years old, but seem limited use. I know that members recommend Porter-Cable buffers, but is the Sears Ranfom Orbital Buffer OK to use, and what type of pad should I use?
Thanks for the advice
Old Jun 21, 2005 | 10:24 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
I really don't think you need anything more then your hands when using NXT, use a foam pad to put it on and microfiber to buff off, it goes on and off very easy, just don't use too much.
Old Jun 21, 2005 | 11:26 PM
ZaneO's Avatar
ZaneO
I would just stick to applying by hand for waxes/sealants.
Old Jun 22, 2005 | 03:31 AM
bugman's Avatar
bugman
have to agree -
NXT is not at all the same as a thick wax product. You take VERY little product and it will spread over a HUGE area of the car, if you use a nice foam applicator pad like the one that comes with it. It's so fast and easy to apply, a buffer is not necessary.
do the whole car at once, even walk away and eat a sandwhich to be sure the whole car has had time to dry. if you don that, it will come off instantly with a MF towel, or I frequently use cotton T-shirts to remove it. It will come off so fast, again, that a buffer is not needed.
you might consider using a polish and then a sealant before you NXT, and in those steps the buffer might be helpful.
Old Jun 22, 2005 | 06:54 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
time to upgrade to a Porter Cable, speed sensitive, and user adjustible.
http://www.autogeek.net/dual-action-polishers.html
Old Jun 22, 2005 | 08:06 AM
easyrider13's Avatar
easyrider13
NXT is a sealant.
To Random Orbital Buffer
