Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Rim Cleaning Techniques
Old Nov 28, 2005 | 08:30 PM
wdweberjr's Avatar
wdweberjr
Cruising
Default Rim Cleaning Techniques
Hey fellow Z06 Owners.....was wondering if anyone has figured out a method that is easy to clean the rims. Any suggestions or ideas, please follow-up.
-Bill
Old Nov 28, 2005 | 08:35 PM
allanlaw's Avatar
allanlaw
-Bill
Only one - take off the wheels one by one and do the job right.
Old Nov 28, 2005 | 08:37 PM
CB1953's Avatar
CB1953
-Bill
Polished or painted?
Old Nov 28, 2005 | 08:45 PM
curvesman's Avatar
curvesman
C2 of the Year Finalist - Unmodified 2020
-Bill
The Wife?
Old Nov 28, 2005 | 09:21 PM
vetteman22's Avatar
vetteman22
I did mine this weekend...painted rims..I have a lift in the garage so its easy to pull all the wheels...washed the crap off the inside of the rims where you normally can't reach it and then rejex them
Old Nov 29, 2005 | 04:22 PM
DPG's Avatar
DPG
St. Jude Donor '06
the first time you have to remove and do a thorough cleaning. But then just take a sponge or whatever you use to wash the wheels and run it inside of the rim. If you wash inside everytime you wash your car, its quick and easy to maintain the hard work that you did when you took then off. Oh and dont forget to polish and wax them after you are done washing the rim when its off the car
Old Nov 29, 2005 | 05:03 PM
ZaneO's Avatar
ZaneO
For heavy cleaning removing them is best, but if you can't, just use a diluted all-purpose cleaner with a spoke brush to get all the hard to reach places. Rinse thoroughly and then wash with car wash soap.
When the wheels are cleaned and dry, put a durable sealant (ie. Zaino, Klasse, etc.) on them to make maintenance easier.
General maintenance shouldn't require more than car wash soap and water with brushes and mitts.
Old Nov 29, 2005 | 05:56 PM
dbirdz06's Avatar
dbirdz06
What is the strongest cleaner you can use on painted wheels to remove the stubborn stains? I've been told Simple Green but what are my other options? I have a few spots on my wheels that will NOT come off with soap and water.
Old Nov 29, 2005 | 06:03 PM
ZaneO's Avatar
ZaneO
You might try Eagle One All Wheel Cleaner. Follow the directions and test an inconspicuous spot first.
ZaneO's Avatar
ZaneO
Old Nov 29, 2005 | 06:41 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
I use a sponge coffee pot cleaner to get inside the barrel good. As long as they are Zaino'd they clean right up.
Old Nov 29, 2005 | 06:47 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
http://www.autogeek.net/pbsrwc32.html
strongest I have found, that does not contain lye or s. acid. It is citric acid based, and safe, when used as directed. Spray and rinse with no wiping needed. Amazing on barrels of wheels also. Just remember wheels should be cool, and must be wet first.
To Rim Cleaning Techniques
