just washed wifes black car and looks 'cloudy' or 'milky'. it was rejexed about two monthes back.i had similar thread a short while ago when klasse aio appeared very much like the rejex does now. both were still shiney and water beaded but both looked 'cloudy'.would i find the same think in same time frame ,6 to 10 weeks, if i had used zaino? by the way on a light colored car i don't think what i am seeing would be noticeable. lastly,yes, i tried some quik detailer and didn't see much difference. thanks bc
2016 C2 of Year
2015 C3 of Year Finalist
I've had real good luck with 3M polishes for cars that need a little help before applying Zaino. They can be hand applied and really set the car up for a nice finish. After the 3M polish, I use Z2, Z6 and then finish with Z8 Grande Finale.
has the car been machine polished with a wool bonnet lately? a wool bonnet will cut deeper than foam, and what you may be seeing is many-many, ultra fine scratches in the clear coat. this will appear to be a milky/cloudy appearance especially a dark color under fluoescent lighting. all you may need to do is polish with a porter-cable D-A machine, a medium foam pad, and a fine cut cleaner. follow that by a swirl remover (medium or fine cut pad), finish off with zaino or and a polish/glaze (fine/ultra fine cut pad). topcoat the later with a quality carnuba.
Hmm...it's really hard to give a sure answer without being able to see/experience the problem, but the car may need a deep polishing to remove any "dead" paint and restore the full luster.
