cleaning high polished wheels
I am taking them off to clean, (first time), and was wondering if the clay bar does not clean them enough,what else should I use,,? :confused:
NCM Ambassador
Cruise-In 1, 2, 6, 8 Veteran
Re: cleaning high polished wheels (repomania)
Are you talking the inside of the wheel or the outside (viewed Part)
The inside usually has alot of grease and crap on it. This might need a degreaser if its real bad. :U The outside should clean up O.K. with the bar. When I did my inside of the '87 I used a degreaser and a scrub/sponge (the non-abrasive kind) forgot what it's called.
Re: cleaning high polished wheels (georgehafe)
george,
the inside,,, so degreaser,, then claybar???
NCM Ambassador
Thats what I would do if they are extremly greasy like mine were. The inside of my wheels are not as highly polished like the outside so I just cleaned them good with whatever took the crap off
