Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
General Cleaning
Old Feb 16, 2006 | 10:14 AM
Fast Cop's Avatar
Fast Cop
Default General Cleaning
I am new at this so please cut me a little slack. I just bought my 1st vette. A 1996 red convertible with black to and black interior with only 40,800 miles on it. I have wanted a corvette ever since I was 8 years old and my dad took me for a ride in his 67 convertible. So now I have one. I am about to embark on the spring cleaning process. I told my wife I will most likly spend more time cleaning than driving as this will be truly a garage queen that will be used on weekends as I have a work car that I use every day. Behind the front wheels alot of greese has built up. I do not want to use anything too strong so I though spraying with simple green and a soft brush to get all the greese off the upper control arm and the greese fitting area. Also any suggestions for engine cleaning as I will be doing the engine and undercarrage. I have already pulled out the seats and did a full cleaning inside. As for waxing any products out their that you all have used with success. I was planning on using black magic or liquid glass. Thanks for any suggestions.
Old Feb 16, 2006 | 10:29 AM
Square's Avatar
Square
I think you will find a lot of answers/opinions/info in the car care section here on the forum.
I have had very good luck with clay bars and Zaino products, personnally.
Old Feb 16, 2006 | 10:33 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I use Simple Green in the same areas that you are talking about and on my wheels with no problem. I use Mothers products for waxing and love the way it looks. Check over in "car care". On the windows try Stoners Invisible Glass it's the best product out there.
Old Feb 16, 2006 | 11:15 AM
bdaly84's Avatar
bdaly84
I have my own detail company, and yes simple green will work wonders on grease, tar, and bugs, just watch your untreated paint areas, as un-diluted simple green will mare and take off the untreated paint. Simple green and a mild bristle brush will clean the control arms and the bushing beautifully. Before that though, if you have the means, use a blowgun attachment to yur compressor and blew the motor and underhood area out. As far as waxes and dressing's, yes I completly agree with joecaver the best over-the-counter waxes IMO also are Mothers and Stoner. Used Mothers for years before I started using the professional grade stuff I order for my company. Still using Stoner products on all my customers vehicles.
Old Feb 16, 2006 | 11:27 AM
Bigredwing's Avatar
Bigredwing
Welcome aboard If you have followed any of the action on this forum for any length of time be prepared for a broad spectrum of advice. This topic will also start a couple of arguments amongst our colleagues. So far with the above. Please update your profile. A "correct color" '96 vert sounds sweet!
Old Feb 16, 2006 | 12:02 PM
Wayne88's Avatar
Wayne88
For tougher grease, I use Degeaser by 'Castrol', its in all the auto stores.
Its not too strong but stronger than Simple Green.
I get the hand spray, not the aerosol, because I have more control over its aim.
I used it for engine grease. It even got the glue off my windows when I removed the tint.
Old Feb 16, 2006 | 12:28 PM
C4driver99's Avatar
C4driver99
Old Feb 16, 2006 | 12:31 PM
rws.1's Avatar
rws.1
I use a 3 parts water, 1 part Simple green in my wheel wells, wheels, tires and engine compartment.
I spray everything when it is cold, let it soak 5 minutes and then rinse well.
You do NOT want to spray Simple Green on hot aluminum engine components. They will discolor.
Visit www.bettercarcare.com and www.properautocare.com
they both have some good how to's for cleaning, clay baring, polishing, removing swirls, glazing, and sealing or waxing.
I like Mezerna polishes, and use a paint sealant not a wax.
I prefer Rejex. But there are many brands. Zaino is very popular on the Forum. Check out the car care section under General....
Enjoy pampering your Vette.....
Rich
Old Feb 16, 2006 | 12:37 PM
Bigredwing's Avatar
Bigredwing
And if you do a really good job your red C4 vert will turn into a cool C5 Vert! Rich, you are truely blessed!
Old Feb 16, 2006 | 04:55 PM
Fast Cop's Avatar
Fast Cop
WOW, this is great, already I am learning so much and some great do's and don'ts on this site. I guess you can teach an old dog new tricks. Well once I learn how to get a picture on here I will post one. Thanks again for all the great advice
Old Feb 16, 2006 | 06:45 PM
Perfusion's Avatar
Perfusion
For your leather, I highly recommend the Lexol line of cleaner and conditioner (orange/brown spray bottles, respectively). Any *good* auto parts place should have it, but if not, check with a local tack shop. If you don't know what that is (it's okay, I didn't for the longest time), it's a place that deals with horse shtuff - saddles, etc. They use it on their saddles...VERY good product. Try it!
Old Feb 16, 2006 | 09:19 PM
Greg Gore's Avatar
Greg Gore
Default Congrats on that Red C4 Vert!
Zaino leather Conditioner leaves your car smelling like new leather inside and nourishes the leather too. A cleaner I like to use under the hood on engine and suspension parts is WD-40. It won't hurt anything and it loosens dirt and grime making it easier to wipe everything down with old rags and leaves a protective coating on parts afterwards to help prevent rust and corrosion. Naturally this is more suited to a garage queen rather than something driven every day or in bad weather. One thing you do not want to do is wash the engine with water due to the likelyhood of getting water in the Optispark and ruining it.
Regards, Greg
Old Feb 17, 2006 | 05:54 AM
bugman's Avatar
bugman
Definitely do some searches in here and on the appropriate vendor web sites, and get these on your short list:
Check my web page when you're really bored. nothing to sell - I just post my own thoughts and favorite products there with plenty of pics.
Check the posts by Killrwheels on washing tips, to prevent swirls. PM me or any of the other guys here if any specific questions. Congratulations - great to have you here !!!
Old Feb 17, 2006 | 07:26 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
http://www.autogeek.net/detailingtips.html
these hints will provide you with a great area to start your detailing regimine. The nice thing is you can stop, reread, and bookmark as needed to look over when those area's need attention. Dont hesitate to email me if you need some additional hints or product choices.
To General Cleaning
