Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
First time claying.......
Old Mar 3, 2006 | 12:36 PM
roscoe118's Avatar
roscoe118
Default First time claying.......
Just wondering how slippery they are
I seem to remember reading here a suggestion to use playtex gloves for a better grip. Will they help? These bars are not cheap enough to drop and throw away
Any suggestions???
Old Mar 3, 2006 | 12:50 PM
SFHC6's Avatar
SFHC6
I have used the clay bar on several vehicles... just used bare hands and never dropped. If you are careful, you should not have any problems.
Old Mar 3, 2006 | 01:05 PM
agentf1's Avatar
agentf1
St. Jude Donor '10
They are not slippery at all, just make sure you use plenty of lube. I use Z7 and water for lube.
Old Mar 3, 2006 | 07:55 PM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
the claybar is not that slippery, its the darn lubrication. I would NOT use gloves as you will not feel the clay working both in areas needing addtl attention, and areas that you can glide over. I would highly suggest Pinnacles Poly Clay, as it comes in multiple pieces "just in case" you drop one though.
Old Mar 3, 2006 | 08:37 PM
Z06-Goose's Avatar
Z06-Goose
That clay bar kit, will be one of the things I'll be buying from you guys soon. Good job there!
-Goose
Old Mar 4, 2006 | 09:45 AM
lostremote's Avatar
lostremote
YOU want to feel the clay working,its really very easy.Just make sure you keep spraying your detail spray in the area you are working so the clay bar glides around.I USUALLY do a 3ft section at a time.I use mothers detailing spray.there are alot of good products out there,so your preference..Also keep kneeding the clay bar ,folding it so you keep getting a new surface.AND TH BOYS ARE RIGHT if you drop it chuck it............ Its alot cheaper getting another bar in comparison of getting a scratch..Remember its not that difficult just pay attention to what your doing.
Old Mar 5, 2006 | 03:39 PM
JJU's Avatar
JJU
Acct Suspended by request 25 MAY 2026
Cruise-In II Veteran
To me they are not slippery but anything can be dropped.
To limit the exposure, I flatten the bar and turn up one edge of the so that if you put your hand flat on top of the bar, the turned up edge is between your thumb and index finger.
To First time claying.......
