Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Question about using Rejex
Old Apr 12, 2006 | 10:24 PM
ShockwaveGT's Avatar
ShockwaveGT
Default Question about using Rejex
Ok...I've been using Zaino pretty faithfully, but am curious to try Rejex just for kicks.
Question is...do I have to remove all the Zaino with a Dawn wash or whatever before using Rejex?
And once the Rejex is on...can I still use Zaino over it and vice versa or does it have to be exclusively one or the other?
Not sure how these two would "bond" together or whatever.
Sorry if this has been discussed...I didn't find anything in the search.
I've seen this on a Rejex site:
"RejeX can be used over existing wax; however, the duration of protection will be reduced as the softer underlying wax degrades comparatively quickly. There is no reason to wax over RejeX. As we’ve already said, RejeX leaves a shinier, longer-lasting finish than wax… and the wax can't adhere well to RejeX!"
So what about Zaino? And if you don't put anything over Rejex...what happens when you wanna deminish swirls with something like ZPC or Mequires Carnuba?
Old Apr 12, 2006 | 10:47 PM
Z06-Goose's Avatar
Z06-Goose
Well, I happened to have read on another board two guys who have done this, and highly recommended it. They applied Rejex over Zaino, and they liked it a lot. So, to answer your question, yes you can.
The use of the ZPC is not an issue because is a paint cleaner and swirl remover and it can be of a great benefit to both products. Wax on the other hand, is not recommended under sealant.
Goose
Old Apr 12, 2006 | 11:02 PM
ZaneO's Avatar
ZaneO
Zaino will not bond properly to other sealants/waxes, and Dawn won't remove Zaino. You'll need a light polish or a strong alcohol wipedown.
Using ZPC or any other paint polish will remove any wax or sealant along with light swirls/defects. Meguiar's Carnauba will not remove any defects.
Using Rejex over Zaino or vice versa won't allow you to truly evaluate the product.
Use them exclusively.
Old Apr 12, 2006 | 11:43 PM
ShockwaveGT
Can I still use the Z6/Z8 quick detailer over Rejex or is that also a no no?
Old Apr 12, 2006 | 11:48 PM
jabez's Avatar
jabez
I tried using the z8 over Rejex and it not work well. It looked the same but the slickness was gone from the Rejex. I recommand using one product and not mixing them.
Old Apr 12, 2006 | 11:52 PM
ShockwaveGT
Ok...I'm curious to give it a shot...It seems like with Rejex...you just apply it once every few months and that's that.
Does it really stay as shiney as when you first apply it?
What do you do after each wash? Like with Zaino...after each wash a quick spray of Z6/Z8 really brings out the shine...
IF you have Rejex do you just not need any sort of quick detail at all?
Where can I buy?
Old Apr 13, 2006 | 12:06 AM
ZaneO's Avatar
ZaneO
Using Rejex doesn't eliminate the "need" for quick detailers, etc. They (CorosionX) just don't make any maintenance products.
Old Apr 13, 2006 | 12:09 AM
ShockwaveGT
Ok, I've decided to stick with Zaino...after reading all the comparisons...I think Zaino is more along the lines of what I like to do.
I think tomorrow I'm going to use my PC with Menzerna IP and FP to clean the paint off and remove as many swirls as I can...then I'll load up on the Z2 again...
thanks for the info...sticking with Zaino.
Old Apr 13, 2006 | 12:23 AM
Z06-Goose's Avatar
Z06-Goose
Where can I buy?
RejeX is a stand alone product.
So far rinsing with water, and wiping dried has worked nice for me. You can tell by the way the shammy glides it won't need QD. Having a QD would be nice to wipe away fingerprints, and things like that you want to do a quick wipe on. Right now, all I want is go at least 5-6 weeks before applying another coat. Then, I'd probably get a QD regardless.
Goose
To order RejeX <--
Old Apr 13, 2006 | 12:31 AM
Z06-Goose's Avatar
Z06-Goose
Why you're backing out after coming this far?
I think with the Menzerna products you've got, this would be a good scenario to lay down some RejeX and tell us how it works for you.
Goose
Old Apr 13, 2006 | 01:02 AM
gringoray's Avatar
gringoray
come on guys... this ain't rocket science. I see no problem using Z6 or Z8 as a QD to Rejex.
Question for Zaino guys, I need more Zaino, I called the Zaino home office in NJ and left 2 messages on their voice mails, this was last week and still no call back. Where can I buy Zaino? I prefer to buy via the telephone not internet.
Thanks-
Old Apr 13, 2006 | 08:40 AM
Zaino Bros (Sal)'s Avatar
0Zaino Bros (Sal)
Supporting Vendor
St. Jude Donor '06-'07-08-'09
Thanks-
Toll Free order line... 888-999-9870
Tech Line 732-833-8800
Old Apr 13, 2006 | 01:05 PM
FIDOauto's Avatar
FIDOauto
I actually like trying one product with the other and found that Zaino doesn't like other products..... for example I did one fender with Mothers paint cleaner and the other with ZPC... when I applied the Z2 it felt much slicker on the side polished with ZPC.
Rejex is starting to sound real good..... anybody know if they got a canadian distributor??
Old Apr 13, 2006 | 03:06 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
I have two coats of Rejex on one of my cars. It is extremely slick.
Will adding an another coat once in a while increase the shine and protection?
Old Apr 13, 2006 | 03:30 PM
mrosa65's Avatar
mrosa65
Yes it will. Like any product that layers, the intial layer will start to break down over time and applying a new one will give it additional protection.
Some users will apply MANY layers in a short period of time, while others will apply a few layers during the first application, then do a "maintenance" layer every month or two. It depends on your driving and environmental conditions on how long the initial treatment will last.
Old Apr 13, 2006 | 09:44 PM
hog driver's Avatar
hog driver
To Question about using Rejex
