Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Bug removal
Old May 1, 2006 | 01:26 PM
vettepoor's Avatar
vettepoor
Active Streak: 90 Days
Default Bug removal
What do you guys (and girls) recommend for removing bugs from your paint? I know WD-40 works well for road oil, but not so for bugs.
Old May 1, 2006 | 01:32 PM
CRABBYJ's Avatar
CRABBYJ
Unmodified C8 of the Year 2021 Finalist
2018 C7 of Year Finalist
Default Many coats of Zaino!
I just wash them off (use Turtle Wax Car wash). They don't seem to stick with my C6's many coats of Zaino.
Old May 1, 2006 | 01:36 PM
Zymurgy's Avatar
Zymurgy
Moderator
Same is true for Rejex, but 2 coats is sufficient. To get them off before you use a good "wax/polish" use a commercial auto tar and bug remover. Wash your car with Dawn to remove old wax. Then use a clay bar to get your paint really clean. Now you are ready for Rejex or Zaino or whatever.
Old May 1, 2006 | 01:37 PM
not08crmanymore's Avatar
not08crmanymore
Default Bugs
I use some stuff from autozone,or just rubbing alchohol.
Old May 1, 2006 | 01:38 PM
2bubbas's Avatar
2bubbas
Same here but I use Rejex.
Old May 1, 2006 | 01:41 PM
xs650's Avatar
xs650
Originally Posted by CRABBYJ
I just wash them off (use Turtle Wax Car awsh). They don't seem to stick with my C6's many coats of Zaino.
It also helps to to wet the the stubborn ones down with car wash soultion and keep them wet for a few minutes before you wipe them off.
Waht's the last thing to go through a bugs mind when it hits your windshield?
PappyTinker's Avatar
PappyTinker
From: Life ain't no dress rehearsal, are you gonna wait to get your toys til AFTER you have a heart attack?
The best way I have found and the way I get bugs off the windscreen of the Harley is to wet a towel with warm water and lay it over the buggy area for a few minutes (not in the sun, of course). The bugs usually come right off with a quick wipe.
Old May 1, 2006 | 01:48 PM
greenshirt77's Avatar
greenshirt77
As already mentioned in the previous posts, if you have a good coat (several is all the better) of a good quality polish like Zaino or Rejex, everything comes off sooooo much easier.
I use Zaino myself.
My wash routine starts with rinsing the car down and immediately spraying some bug splatter remover on all noticable blood and guts. (I can't remember the last brand I used, but it worked really well. I will look at the bottle when I get home and post)
Let that sit a few minutes while you fill your buckets, etc., then rinse off well. Most of the carnage should rinse off, and what's left comes off easy when you soap her up.
I also use the Zaino Z7 wash and it is by far the best I've used. The combo of a good polish base and a good soap makes it all the easier to clean off the car w/o having to use alot of elbow grease and reduces the amount of scratches/swirl marks.
Old May 1, 2006 | 01:50 PM
greenshirt77
"HEY!? Is that one of those new Corv...".
Old May 1, 2006 | 02:55 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
To remove bugs i use a hand-wand soapy car wash for the entire car, then go back and rub the buggy areas with a wet 100% cotton towel. That removes the bugs without scratching, then I finish the wand-wash normally.
Old May 1, 2006 | 02:59 PM
vette-oholic's Avatar
vette-oholic
I use the bug/tar removal sponge thing that you can get from pep boys. It's sorta of netted. Use pleny of soap & water with it. It works great but takes some time.
Old May 1, 2006 | 03:22 PM
PapaTango's Avatar
PapaTango
His butt!
Old May 1, 2006 | 03:23 PM
xs650's Avatar
xs650
Originally Posted by PapaTango
His butt!
Old May 1, 2006 | 03:42 PM
jackv92126@yahoo.com's Avatar
Default Bug Removal
I Have Tried To Use Peanut Butter . Apply It Where The Bugs Are Wait For About Half An Hour To Let The Oil Penetrate The Dried Up Bugs Then Wipe It Off. Hope This Work For You It Worked On Mine.
Old May 1, 2006 | 04:23 PM
bullets1's Avatar
bullets1
How about a conveniet method/product if you're on a road trip?
Old May 1, 2006 | 04:27 PM
grywlfbg's Avatar
grywlfbg
Follow PappyT's advice above. Grab a hotel hand towel, wet it w/ hot water and lay it on the affected area. Give it a few minutes and it'll wipe right off. I use this trick on my motorcycles all the time - course they're a little smaller than the Vette but it'll work just the same.
Old May 1, 2006 | 04:56 PM
BigJoe's Avatar
BigJoe
For really tough ones I use 3M Tar and Bug Remover. Works great but it also removes ALL wax.
To Bug removal
Old May 1, 2006 | 05:01 PM
bigearl56's Avatar
bigearl56
Default Love that Post!
greenshirt77, Man you are too too much.
Old May 1, 2006 | 05:15 PM
05C6400's Avatar
05C6400
Turtle Wax Bug & Tar remover works well too.
Old May 1, 2006 | 05:16 PM
xs650's Avatar
xs650
It's also another good wax remover.
