Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
Bugs...Bugs...Bugs
Old May 28, 2006 | 10:52 AM
tsgrayson's Avatar
tsgrayson
Default Bugs...Bugs...Bugs
What is the best way to get their remains off the car??
Old May 28, 2006 | 10:58 AM
mrosa65's Avatar
mrosa65
If you do a quick search you can find many different ways.
Before I try anything of the chemical method, I personally will take a towel, wet it with water and then lay it on the area of the paint where the bugs are. I do this inside my garage out of the sun of course.
Normally, they come right off with ease. I also like to carry a bottle of detail spray in the car this time of year since it's love bug season here in Florida. They can bake on pretty quick in this heat so I try to get them taken care of as soon as possible.
Old May 28, 2006 | 11:04 AM
tsgrayson's Avatar
tsgrayson
I think I might have some baked on
Old May 28, 2006 | 11:07 AM
ZaneO's Avatar
ZaneO
I've found that using a small amount of swirl mark remover on a microfiber towel works well for removing stubborn bugs and tar.
Old May 28, 2006 | 11:24 AM
tsgrayson's Avatar
tsgrayson
Ok for black?
Old May 28, 2006 | 12:13 PM
TH0001@properautocare.com's Avatar
0TH0001@properautocare.com
Former Vendor
I wouldn't recommend that method, because it sounds like an elbow grease method where you could potentially be grinding bug remains against the surface of your vehicle.
The water method might work good (with the towels, never tried it but I will, since it makes sense). I recommend spraying the bug remains with a citrus based bug and tar remover and letting it soak according to manufactors recommendations. The blot with a towel to try to remove as much remains as possible, repeating the application. You should be able to blot most of the remains away, the lightly agiate the remains to loosen them, before blotting again.
When you get most off, spray with your favorite quick detailer and gently wipe off.
Old May 28, 2006 | 12:22 PM
ZaneO's Avatar
ZaneO
I didn't say elbow grease - it's only an elbow grease method if you make it one.
As long as the vehicle is properly cleaned and one uses common sense, it works perfectly fine.
As with Bug and Tar removers, wax/sealant will need to be reapplied to affected areas.
Old May 28, 2006 | 12:32 PM
gmblack3's Avatar
gmblack3
Poor boys bug squash works great.
I QEW washed this car, on the front I applied Bug squash while it was still wet from the QEW. Let it sit for 10 mins, then wipe with QEW soaked MF again all gone.
You can do this with a hose wash as well. I would not do it in direct sunlight.
Of course the car was polished, ect after. But the bugs where gone after the above process.
Old May 28, 2006 | 12:42 PM
Former Vendor
Most swirl removers (unless I am thinking of something else, which I could be) use abrasives which will remove wax/sealent also. I guess its a matter of preferance, I have never tried it. I think the best protection against bugs is having several layers of protection built up between paint and the contaminents. They should hose off easily.
Again, I recommend always keeping a quick detailer of sorts in your vehicle and removing them as quick as possible, before they can cake on and etch into your clear coat.
Old May 28, 2006 | 12:45 PM
ZaneO's Avatar
ZaneO
Just as most bug and tar removers will.
He was asking about baked in/on bugs...QDs are great for fresh bugs, but I've never seen a QD touch bug etchings before.
Old May 28, 2006 | 08:40 PM
LS WON's Avatar
LS WON
Wd-40
Old May 29, 2006 | 10:41 AM
LA2NYC5's Avatar
LA2NYC5
3rd Gear
Hi, seems like that works for you. What about road tar, blacktop etc? Any suggestions for that?
Old May 29, 2006 | 10:59 AM
Killrwheels@Autogeek's Avatar
0Killrwheels@Autogeek
Former Vendor
http://www.autogeek.net/poorboys-bug-squash.html
Poorboys Bug Squash --- works well on tar also.
Old May 29, 2006 | 08:32 PM
tsgrayson's Avatar
tsgrayson
Water is working good at the moment...Man...does TN suck for bugs or what???
Old May 29, 2006 | 09:06 PM
tsgrayson's Avatar
tsgrayson
ok..what about bugs on the lights...I have one who will not come off with anything!!
Old May 29, 2006 | 09:16 PM
feeder82's Avatar
feeder82
I have a couple of good coats of Zaino on my Vette, when I get home after a cruise I either soakl the bugs with detail spray or jsut plain water from a spray bottle and they wipe right off without scrubbing, even the dryed june bug and butterfly guts
Old May 31, 2006 | 01:32 PM
BananaVett's Avatar
BananaVett
I clay my car after every wash, and I sometimes use auto clay just to remove the bugs, then just use a wax. Claying works.
My vette is yellow, and yellow really attracts bugs to my paint when I fuel up or just in the garage with the door open!
To Bugs...Bugs...Bugs
Old Jun 20, 2006 | 12:37 AM
tsgrayson's Avatar
tsgrayson
Ok...I have two bugs that just will not come off with any product that
I use...clay, bug and tar remover, everything....any ideas???
Old Jun 20, 2006 | 09:13 AM
ZaneO's Avatar
ZaneO
Did you try a light swirl mark remover?
Old Jun 20, 2006 | 12:29 PM
LS WON's Avatar
LS WON
See the movie "Starship Troopers"
