Does anyone have a good way to remove bugs from the front of the car with out buying a bra. In the past just washing worked, but now it seems I have a few more stubborn remains.
I usually use off the shelf bug removes work well. For the really stubburn bugs, those nylon disk scrub pads work great. Wet down the area with soapy water and scrub ever so gently. Works grat on windows. Kinda like the squeeges at the gas station
If you put several coats of Zaino, NXT, Regex on, they will wash off with just water. I am always afraid to use tar and bug remover on my car as, what else is it removing along with the bugs.
I wash first with a soft damp towel, and then get the stuck ones off with Turtle Wax tar & bug remover (in the black spray bottle). I usually just spray a little bit on a sof cloth instead of directly on the car. It is not abrasive to the clear coat finish.
I use a very old technique for removing bug splatter. Get a piece of your wife's old nylon stockings and roll it into a small ball. Then wet it with a liquid dishwasher soap...something like Dawn works well. Just rub the bug juice off. It works very well and I've never seen it harm the finish of any car I've used it on.
From: Heaven, for the climate; Hell, for the company
Love bugs.
Wash as much off with just water -- soft spray, not jet. Then spray detailer -- I use Meguiars, but any should do -- onto a soft cotton cloth, lay it over the buggy areas -- no scrubbing. Leave it on for a couple of hours, respray if it looks like drying. Remove cloth, water spray again, and wipe with micro or soft cotton. Then re-wax. Always has done the trick.
Use tar and bug remover to get them off. Then use Rejex and bugs won't stick anymore.
4 coats of Rejex on mine and they still stick! No better to get off than regular wax. I used meguires Gold Class for years and Rejex is no better to get bugs off of.
First wash the car with slightly soapy water as you would usually do, then use a claybar with soap/lubricant to remove remaining bug guts. I have found the claybar is much less likely to scratch the clearcoat than a nylon scrubbie. Follow up with a good polymer sealant like Zaino (my favorite) or Rejex. Last week my fiancee had paint (from the highway dept having just painted lines on the road) spewed all over the lower half of the car. Claybar removed it with incredible ease and no visible damage to the paint. If you have never used this stuff before, try it out as I know you will love it!!!!!!!!!!!
P.S. Good to clean windshields too.
I have offered this suggestion before but I don't think anyone has tried it. It works great and is so easy. I took bugs off my wifes car after 6 days with ease.
Buy the cheapest store brand dryer sheets. The ones you put in the dryer with your clothes. Dampen it and the bugs come right off. You have to use water after to get the little residue off. I use them on my wife's QX56, my C6 and my Cobra
Here is what happened to my wifes BMW 3 days ago going across Florida SR70. The car was perfectly clean and waxed 4 hours earlier. It eventually washed off using lots of soap and water. For the ride home, I sprayed the front of the car and side mirrors with "Pam" cooking spray. The bugs rinsed off with just water from a hose. Everyone in St Pete was waiting to see my Vette. Not during Lovebug season.
Originally Posted by xcutter
... I sprayed the front of the car and side mirrors with "Pam" cooking spray. The bugs rinsed off with just water from a hose.
Pammed a Volvo in 1997 -- drove 450 miles to Tallahassee in Florida early summer heat -- Pam turned brown and sticky -- bugs stuck in Pam. Mineral spirits got it off, but wouldn't do it again.
Even with Rejex or Zaino, you are still going to get bugs stuck to your car (I do). All depends on how big a bug and how long its been on there. If its just a few bugs, I'll use some quick detailer and a micro fiber cloth to wipe them off. If you have the situation like the BMW above, you have to wash with soap and water and a good bug sponge. Using Dawn will strip the wax off the car, so if you use that be prepared to wax the car afterwards. Same with dryer sheets.
Pam non stick spray also works, but I don't know how long it remains effective and what effect it eventually has on your finish.
Spray with plain old warm water, let sit a minute, wipe off, then spray repeat til they are gone. You don't need any chemicals, just moisture will rehydrate the little dead bug bodies and cause them to release from the paint. Especially if you keep a few coats of any wax on the vehicle.
Once you're done, just add a little gloss wipe-on-wipe-off kinda stuff (I use zaino z7 I think it is--the gloss enhancer) and they will continue to come off easily in the future (as long as you have wax on car). If you have some Harley Gloss laying around, use that.
Out here in the 110 degree summer heat, the bugs cook on the paint (especially after driving thru them all day long). A bra was an absolute necessity, and has the added benefit of protecting against all the birds and rocks I frequently encounter. And the bra is easy to clean off, despite what bra naysayers opine.
I'd rather have baked on bugs on the bra and not have to babysit the front end paint all the time. Nothing worse than getting home at midnight from driving all day and having to give the car a wipe down. No thanks. Tired of that. Since installing the bra, those 30-minute wipe downs are now just 5-minutes, and can wait til the next day.
I wanna spend my time driving the vette not bathing it.
6speedC6 you are the man. I took your suggestion and used Bounce. Incredible, it worked like a charm. Afterwards I washed the area with car soap and bug guts were gone. Thanks.
I just put on several coats of Rejex after washing my car and then any bug or love bugs (live in florida) just rinse off with a hose. Any thing left (which is not much) comes off with a little soap and water.
