3M Clear Bra - Cleaning/Polishing?
As all have said... treat as you do your paint. I have had it on multiple vehicles with no yellowing.
Use QD to clean up bugs. I also use Rejex on mine. I have found it makes it easier to remove the bug residue.
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
My clear bra has been on for 18 months. I waxed it ONCE...big mistake. The "haze" was horrible. If you look at all my shots on the beach, not one is from the front, cuz that was the day it did it.
Now I use Eagle One "Wax as U Dry" and their spray detailer. I now only wax the car (with their nano wax) once a month and use the other two all the other times. NEVER get close to the edge of the clear bra with wax. Nothing worse than white crap showing all over the place.
$0.02.
$0.02.
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
$0.02.
$0.02.
Plexus
Originally Posted by blkvette1
OK - simple question - what do you guys/girls use to clean and polish your 3M Clear Bra material (obviously you must have one to answer this)?
I heard standard wax will make it yellow over time.
What are costs of the clear bras?
With a black car that will be driven on a 35 mile one way interstate commute fairly often, the clear bra sound like it could be a very good hood nose saver.
Is the overall physical coverage of your car the same as the fabric ones or can you get more of your hood covered with this?
What kind of cost w/ installation?
The Cost Of Clear Bras
