Question
You can spend some time doing the zaino routine and not really have to mess with it for 4-6 months or give it a quickie and have to do the same in a month or two. The later depends on what you use.
I know that Z5pro looks excellent on a black vette:
http://forums.corvetteforum.com/show...ighlight=black
You can test the clean surface by placing a sandwich bag over your hand and lighly rubbing the surface to see if it feels rough. If it does clay it.
Is it garaged or kept outside ?
Are you looking for a product that will last a long time or would you rather apply it every month or so ?
I see you mentioned that paint doesn't have any swirls or other imperfections, does that include minor scratches ?
As for the claybar, an easy test is to wash and dry the car. After it's dry, put your fingers inside of a baggie and gently slide it across your paint. Does it feel gritty or rough ? If it does, then you could/should use a claybar on it. Is it mandatory that you do ? Of course not, but it will help the overall appearance of your paint.
I have read about the Z5pro and most people seem to be pretty happy with the results. Is that something I can just use following a wash or will it only produce the advertised results following clay and the Z1 Show Car Polish Lok or ZFX? Also, is the Z6 gloss enhancer spray worth getting as well?
I would use Z5p/Zfx on it. I think the Z5p has a slight edge over Z2p on black. The Z6 is definitely worth it but for your case I might reccommend the Z8 instead. Z8 is like Z6 on steroids and will actually add some polish to your finish extending its life and giving the black that little extra depth and wetness it sometimes needs.
It will look good if you don't clay so no need to worry about that. Most of us on this forum are pretty **** about our vehicles and go the extra distance and use the clay to take the finish to the ultimate level. I've done it both ways on black since all 3 of my vehicles are black (I never learn
). The Z6 is really good for a regular quick detailer. I also use the Z8 which is like Z6 on steroids. It's a little more expensive and I only use it every few weeks just to add some additional "pop" to my paint.
Since the car is garage kept, you could use the Z5pro, do normal washes and hit it with Z8 every few weeks after a wash. That's the routine I use and it works really well for my needs. It's been many months since my last coat of Zaino and I still get tons of compliments on the look of the cars finish.
As for application time. If you wanted to put on more than one coat of Z5pro the same day to help hide some of those minor scratches, I would get the ZFX. Average time to put it on seems to be around 20-30 minutes per coat. Drying time will vary, but typically is around 30 minutes. So you're looking at a few hours to put on 2 or so coats. The nice thing is that once it's on, it will last you months and you can just wash in between like you've been doing and then spend maybe 20 minutes every few weeks to mist some Z8 on there.
Hope this helps.
Again, this was *my* experience while using NXT and I'm sure others will post with different opinions.
NXT has very poor durability. I barely got two washes out of it, when you compare that to Zaino which last for months there really is no comparison between the two IMHO.
Durability is not a huge issue with me. I am looking for a easy to apply product that is readily available off the shelf and that seems to be Meguiars. The internet botique products are fine but if you find yourself needing a certain product Saturday afternoon forget it. It won't be on the store shelves.
I would just go with 3M IHG if I was you.
certainly NXT will give you a nice gloss, and can fill in and conceal some swirlmarks. But you'll really do SOOOO much better if you go with Z5Pro- regardless of whether you want to do the entire clay routine or not. But claying the car is really not a hassle. No more than 20 minutes to do the hood and trunk, which are the key places. The vertical surfaces are less important for claying.
