Car Care Discussion Car Detailing Info, Wax, Wheel Polish, Interior Cleaning Tips for the Corvette
clear coat problems
Old Sep 26, 2006 | 07:56 AM
rkort's Avatar
rkort
Default clear coat problems
i have a couple of area that look like the clear coat has be damages or spotted, they are about the size of a quarter the biggest area is on the back seem to be a 2"x3" area. the car in mag-red can't see the problem area unless you look at them at a certain angle. any way to fix this with out a repaint.
thanks
Old Sep 26, 2006 | 09:37 AM
agentf1's Avatar
agentf1
St. Jude Donor '10
What type of damage? any pics? If it is just on the surface of the cc it can usually be fixed by buffing or even sanding and buffing but if it is something like thin or failing cc repaint is usually the only fix.
Old Sep 26, 2006 | 10:21 AM
rkort's Avatar
rkort
Problems seem to be like stain, like from an egg being thrown on it, or bird sh*t that has sat for a while, sorry at work no picture.
Old Sep 26, 2006 | 11:41 AM
agentf1's Avatar
agentf1
St. Jude Donor '10
Try what I mentioned above starting with the least aggressive method. Try something like 3M 39009 or Zaino Fusion if you have it. Do it by hand first, then step up to a machine like a ROB if by hand doesn't work. If the ROB does not work I would step up to a Rotary and then finally a quick wet sand with 3000 and repolish to a shine if all else fails. You need to be careful that it is not so deep or you don't remove too much clear coat or you could have bigger problems. You could also try a more aggresive polish like 3m 39002 or Menzerna IP if the mild ones mentioned above don't work before going to the wet sanding step which is very aggressive.
Old Sep 27, 2006 | 03:00 AM
bugman's Avatar
bugman
yes - please post up a pic when you get home and have a chance.
really difficult to say much further without a pic to help.
All agentf1 said is of course correct, but if your problem is, in fact, areas of clearcoat failure then you can skip it all and go right to the paint shop.
Old Sep 27, 2006 | 09:46 AM
rkort's Avatar
rkort
will try, may be hard to shoot
Old Sep 27, 2006 | 07:09 PM
rkort's Avatar
rkort
I am sorry I try to add the picture, but the attached button keeps asking for a url. I thought that I was knowledgeable about this stuff . But this has throne me for a loop. How do people attached picture to the forum I look under FAQ but couldn’t find any thing .
Help
Old Sep 27, 2006 | 10:59 PM
Z06-Goose's Avatar
Z06-Goose
thanks
What year is your car, what kind of products have you been using?
Goose
Old Sep 28, 2006 | 01:01 AM
TonyC6's Avatar
TonyC6
Help
go to a site like Photobucket.com and upload your pics to that site. Then, in your post simply copy the IMG file and paste it into your post. You will see what I mean when you get to Photobucket. Each pic you upload will automatically be assigned the appropriate coding. You can even resize your pics on there to fit better in the post.
good luck!
Old Sep 28, 2006 | 08:00 AM
rkort's Avatar
rkort
thanks for the info, i will try tonight, this will be hard working late,
i have 2000 mag-red
once again thanks for all the help
Old Sep 29, 2006 | 07:59 AM
rkort's Avatar
rkort
here are the picture of the rear stain
hope you can see the stain on the hood also
Old Sep 29, 2006 | 09:41 AM
TOGWT's Avatar
TOGWT
From: Ponte Vedra Beach / London State: Dazed and confused
It appears to be acid etching (at least on the hood)
Old Sep 29, 2006 | 12:36 PM
rkort's Avatar
rkort
what iam doing wrong, how do i get the picture to come up in the post
help
Old Sep 29, 2006 | 12:51 PM
mrosa65's Avatar
mrosa65
help
Some sites won't allow you to direct link to the pictures. From what I can tell you copied the address from your browser address line then inserted it into the post by using the "insert image" tool in the posting window.
Give this a try, go to your photobucket photo, right click on it. Then select properties. Highlight the address/URL portion which will look like this.
http://i104.photobucket.com/albums/m...t/P9270122.jpg
And then right click the highlighted address and select copy.
Then when you start a new post, use the "insert image" button and paste that address into it. So you should see this.
We can work on resizing the images later. If you need more help just let me know.
Mike
agentf1's Avatar
agentf1
St. Jude Donor '10
help
Put [img]your image path[/img]
Old Sep 29, 2006 | 01:00 PM
mrosa65's Avatar
mrosa65
Frank
I already thought of that and tried it and I get this.
But if I go to the link and get the photo's URL from hitting properties then I can display his image.
The direct URL is
i104.photobucket.com/albums/m190/rogerkort/P9270122.jpg
I had to remove the http portion in front of the URL above or it will truncate it to look like this
and if you add the image tags as you mentioned it works fine. Seems that photobucket is doing an internal redirect.
Old Sep 29, 2006 | 02:00 PM
rkort's Avatar
rkort
lets try it again
To clear coat problems
Old Sep 29, 2006 | 02:02 PM
rkort's Avatar
rkort
got to add the picture how do you get the size adjusted to a bigger size
Old Sep 29, 2006 | 02:15 PM
mrosa65's Avatar
mrosa65
When you went to your photobucket account, I believe you clicked on the "thumbnail" picture and then followed my instructions.
Take it on step further before doing what I suggested.
Go to photobucket, click on the small picture that you want and it should bring up the full sized photo. Now follow what I posted earlier.
Or if you want to cheat a little.
This is the URL of the thumbnail
s104.photobucket.com/albums/m190/rogerkort/th_P9270125.jpg
Just copy and paste it like you did, but remove the th_ as bolded above and you should get this
Old Sep 29, 2006 | 03:07 PM
rkort's Avatar
rkort
first let me say thanks to MROSA65 for all the help .
but i had to try it just to see if i can do it
