I had sprayed some spray glue in my garage and some got on the paint of my car and it's "black" as well as some on the windshield and side window. Now, I wanted to know what can I do about this - besides never doing it again! What products should I use on the Paint and Window.
Thanks for the responses' I fell better that I wont have to repaint the car:
What is my best option:
1- use goo gone on the paint and window
2- use clay, polish and sealant
3- scratch remover then polish and seal
4- Use body solvent then polish and seal
You dont think that using Goo Gone on the Paint would be an issue?
Thanks,
TonyP
I've used it on both my motorcycle (removing gas tank label) and my cars. If you have concerns, try it on a painted area (say under the hood) just to test color fastness.
have no fears about goo gone, turpentine, paint thinner -- none will harm your cured clearcoat. shouldn't be difficult to remove this stuff since is was sprayed recently.
