Just be very careful! I did the same, but somehow a small particle must have gotten lodged in the rubber. LONG scratches ALL over my black SS. Took me hours to buff out. I still use it, but only on windows and on my white truck.
One thing that got me real bad is I lightly touched the finish of my car with finger and saw a scratch I had just caused. It scratches easy is this normal?
Not normal, unless, obviously, you had something on your finger.
Must have been that time of the month and she didn't want to be touched.
One thing for sure next time if I ever do that again I won't sort of like when you see people write on a dirty car wash me well picture that embedded into the paint
This is what I use for blowing out the mirrors, door handles, nooks etc.
It's small and has a rubber nozzle.
Hold it with one hand and wipe the drips with the other hand.
I have been using a blower for about 3 years now....
due to the nature of my business I need to wash/wax a car with no waiting for all water in the cracks to dry. The blower is very useful for making your vehicle 'COMPLETELY' dry in minutes, I dont worry about blowing dirt back onto the paint because I work indoors and at any given time you could eat off of my floor....
my biggest pet peeve is removing an LSP and water keeps trickling onto my dry towel!! IT DRIVES ME NUTS!!
p.s. The blower is mostly effective when the vehicle is waxed/sealed etc....
A rubber nozzle might be a great idea because there have been time I have come to close to paint finish with supplied tube. I would hate to put a scratch in with the blower when it is suppose to keeps the sratches from happening.
IF one wants more air blow to be stronger wouldn't changing the nozzle to a larger diameter tube be better? or would this just dissipate the air weaker?
Actually, just the opposite. Smaller outlet = higer wind force. Think about when you put your finger over the end of a hose. Same thing.
I have a Stihl blower. When I got it, the next model up was $75 more and claimed something like 50-75 more mph. The ONLY difference was the end nozzle (it was compressed like a thin oval vs. a round opening). They happened to sell the compressed nozzle for $10, so.....
On the Craftsman it has small openings that are tapered down. I would have thought a plain old straight larger diameter tube would have been better but it must be that the air is more concentrated with the smaller nozzle.
Leaf blowers are the way to go to remove water after washing. I would only use electric though; gas blowers can leave an oil film It gets the water away from areas you can not reach with drying cloths; headlights, tail lights, side lights, door jambs, emblems, windshield wipers, wheels, brakes, etc. You do need to be careful and not hit car finishes with blower.
I've done it both ways - you do not want a machine with a small opening. you want a 220 MPH stream in as large an area as possible. if the stream is just concentrated on a small spot, you'll just move water around, and take forever to clear it off the car.
I have a Toro with a great wide oval outlet tube. get something like that.
If you get a chance check out that Craftsman it is rated at 220 MPH #74826 it is red and the funnel for blowing does have 3 little holes at the end the one in the middle is no more maybe less than an inch and the two holes on the side are maybe 1/2 or less. The tube for the vacuum is BIG.
Let me put it this way after 10 minutes of drying maybe 15 minutes there is still some water on the hood or around the car. It isn't completely dry. The mirrors are dry but places on the rear hatch and tops of car and hood seem difficult to COMPLETELY remove and windshield too..
What is the average times to COMPLETELY dry a C-6 if it's possible with a blower?
If there is still water on the car after that much blowing, you probably dont have a very good coat of sealant/wax/whatever. I'd Zaino or Rejex it.
I dont get ALL the water off with the blower. Just most of it. I always go over the entire thing with a micro fiber towel and a light touch. A little Z8 if some spots didnt get clean.
Try this....
First step - Zaino it!
Wash as usual
Remove the sprayer from the garden hose and let the water free flow onto the car. If it has been Zaino'ed, most of the water will sheet and flow off.
Use the blower in all the places mentioned by possessed and the rest of the car.
Lightly follow up with a micro fiber towel.
Try this....
Wash as usual
Sounds time consuming, but it really isn't.
I have over 10 coats of Zaino on car perhaps I have to figure that I will be using a micro-fiber towel anyway as I didn't want to have to touch paint finish. I want to have the least amount of contact with paint as possible.
clemsondave is right.
do the nozzleless rinse first.
then I spend no more than 5 or 6 minutes from the top downward with the leaf blower. YOu do not want to attempt to get the car totally dry, just get the majority of the water off the car, and attention to the cracks, the wheels, the mirrors, the tailpipes.
Then get your MF towel and z6 and spray lightly as you remove the last few drops of water.
one of the major advantages of the blower for me is to get the water off the brakes and wheel barrels, so I don't end up with water spots on the barrels, and even worse -- RUST from the rotors all over the place.
