ClayBar
I still have it, it's blue and very stiff. I now use the stuff that Griot's Garage sells. It is much softer and easier to use than the old stuff.
a) Fine- clay that abrades or shears light surface or imbedded paint contamination and encapsulates it. This type of clay is mild enough for use.
b) Medium- clay is used to remove heavier surface contaminants (bird excrement and bug reside) it is slightly more abrasive than the fine grade and abrades the paint surface, while the clay encapsulates it
c) Medium to Heavy duty- clay is used to remove paint over-spray; it contains a slightly stronger abrasive that abrades the paint, while the clay encapsulates it
There are only a couple manufactures of clay and patents protect the technology, with some subtle difference
(Elastic and Poly) in consistency and firmness, a recent court hearing found components of the “elastic clay” to be a patent infringement and the judge ordered sale of the product to be halted. (In the United States, AWC sells Clay Magic®, the original surface preparation bar.
Auto Wax owns six patents relating to clay products and provides private label clay to many of the detail industry’s leading companies - http://www.automagic.biz/specialt.htm
As a result, all of the Polybutene (Polyisobutylene) or plastic clay being manufactured now comes from the same factory in Japan, which as the only patent holder has a monopoly on the market. Meguiars, Mothers, Sonus, Zaino, et al get their clay either from Japan or from a US licensed manufacturer. But the formulation can vary significantly, mainly;
- Density or plasticity
- Abrasive particulate size
- Abrasive used (i.e. Kaolin, diatomaceous earth, etc)
- Abrasive density ratio ( abrasive content to clay)
- Colour
Knowledge - [We know a subject] [We know where to find information on it] the most highly valued; [knowledge that is both held and shared]
